  • 1 month later...
  • 1 month later...
Look for r33 door handle surround. Piece behind the door Handle interior mine broke when I took them off thank you!
If you mean what I think you mean then these should be right. Not sure about interior colour though. They are the same for front and rear doors for a sedan as well.
ESCUTCHEON-INSIDE HANDLE LH - 80683-70T02
ESCUTCHEON-INSIDE HANDLE RH - 80682-70T02
  • 4 weeks later...
er34-031157
GGKBRTFR34UDA-JJ-F
5/2000
Needing part number for
coolant overflow bottle cap
and on the oil cap.. if the seal comes seperate or part number for the whole cap!
Muchly appreciated!!
er34-031157
GGKBRTFR34UDA-JJ-F
5/2000
Coolant overflow bottle cap 21712-50M01-
Oil cap 15255-1P103-
13276-4P100-
hi
i was wondering if you can give me the part number for the oil filter housing on a rb20det for an r32
also for a remote control key for an r34 gt-t
thanks
steve
Oil filter bracket
15238-80S00-
Gasket
15239-71L00-
Remote control key
H0564-C9920- ??????
  • 3 weeks later...
  • 3 weeks later...
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
