As recommended by the brakes sticky i got some R33 rotors machined down 6mm for my S2 Turbo.
I have found that these DO NOT fit. They sit too far back and rub against the caliper so do not buy them unless you feel like grinding the caliper away, which i am going to do over the weekend. I would recommend going with the genuine items from Nissan or upgrading the calipers.
Have also found that DB1398 pads may fit S2 stageas as well. Will be investigating this option.
If anyone has fitted R33 rotors to an S2 could you please let me know how you got on?
Pretty peeved at the moment having spent about $450 for no gain as yet.
Oh well thats the life of a stag.
Edited by GorGasm
I've heard this happy to one of my friend's S1 as well. Potentially it can be dangerous as they rub they will slowly break away preventing sudden stoppage-effectiveness.
Good luck - got pics of your calipers?
The car is an S2, so S2 calipers. DB1398 appear to be the fitment although i have a different brand of pad from japan.
Heres some pics of the gear. The new disc fouls on the back side against the top outside edge of the caliper support.
I think the recommendation should be removed from the brakes sticky but i dunno whether that will happen.
DO you have a pic of where they are hitting, or can you draw up some tricky paint picture? If the rotor is not sitting in the centre of the caliper you can just space it out with some shims, if the disc is too wide in diamter, machine it down a bit more?
Hey there. Ive hacked up an image of where it contacts. Its rubbing on the back side edge of the disc against the caliper support. I think the offset is different to the standard disc and i think the disc might be a bit wider as well so im having my doubts as to whether these are going to work at all.
Im going to see if i can fit the new disc and new pads in the caliper tomorrow. If i can get that to work i think i will see if the disc sits in the centre of the caliper. If it does i will grind the caliper support a bit. If its not centred then i may look into getting spacers.
If the new gear doesnt fit in the caliper then i think i will throw in the towel and have an expensive set of paper weights, im expecting this and after spending about $450 on discs and machining im pretty pissed off about it to be honest, only myself to blame for relying on the internet i guess.
Moral of the story so far is dont trust internet forums to give you the correct parts fitments.
Circled is the contact area.
Righto. Had a bit of a play around today. The R33 rotors will not fit at all without a 5mm spacer behind the rotor. Im not sure if this is dodgy or what. Also i believe the R33 rotor is wider at 30mm when the original rotor appears to be 28mm. So even with a spacer you would need the pads machined down to fit in the caliper.
On the upside i managed to fit new brake pads no worries. S2 pads are the ones in the link below, which are db1398s:
http://www.fujibrake.co.jp/pads/fblpad_e.php?fblno=AFP385S
I managed to get a hold of KASHIYAMA [ D1231M ] and they are a perfect fit.
$400 door stops, yay!!
joe, id advise going genuine or getting a hold of some specific rotors from japan, i think there is anything available in nz or aus for our cars.
The dimensions I was given for the front rotors for an S2 Stagea were off an RS4. I have fitted the R33GTST rotors to an S2 RS4 and they fit perfectly (after machining down the 6 mm of course). So I can only assume that the RS-V is different. The way to confirm this is to measure the standard RS-V rotors.
These are the dimensions of the RS4 front rotor (R33GTST in brackets);
OD = 290 mm (296 mm)
New height = 54 mm (54 mm)
New rotor thickness = 28 mm (30 mm)
Minimum thickness = 26 mm (28 mm)
Centre hole ID= 68 mm (68 mm)
Studs = 5 (5)
Obviously the dimension in question is the height (ie; 54 mm).
It is worth mention that ALL R32's, R33's, R34's (including Brembo equipped ones) plus S14's and S15's come with front rotors of 54 mm height.
There was sufficient room (with the pistons fully retracted in the callipers) to fit the Bendix brake padss, ie; the extra 1 mm of rotor thickness (each side), was not an issue.
:D cheers :rofl:
dont Series 1 use DB1398?
perhaps S2 RWD stagea's use S1 AWD brakes?
what size are the S1 stag rotors, 280mm? if so, that S13 disc would be a perfect fit..
however, i have some yellow R33 GTS-T calipers that would suit your car perfectly. :thumbsup:
The 2WD and AWD Stageas have different front suspension layouts, so could this be a factor? Maybe the front brakes are also different between the 2WD and AWD models.
anyone wanna buy some s2 rs4 slotted rotors? :]
Hmm... i'm a bit lost with this, so this WILL fit a Series 2 RS4? And you have a RS-V which require different sized rotors? If these do fit I might definitely be interested. Any difference with front and rear rotors?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
