Gms R32 Doco
Another vote for the 1990 livery. Much nicer than the 91 effort.
By the way, what was the number of the chassis Skaife wrote off at the 1990 Australian GP? And does anyone have any photos???
  • Replies 57
They were the Jap spec Nissan/ Nismo wheels. That mob is SA ended up doing the Nissan Motorsport Aus rims for the R32s much like that had for the R31s. I think its the same mob that are doing the wheels for Triple 888 and the Fords?!!!?!?!?
I think its Auto Tek, or made under contract to Autotek. I know the magnesium wheels for the R31 GTSR cost a small fortune. The japanese used BBS or something, Gibson the locally made rims.
I think the NSW crew is now running them as a result of their 18" Simmons not being correct. So maybe its something R31_Gun can answer quickly through Terry Ashwood. I doubt his rims are used magnesium wheels from 1990 :domokun:
Interesting it still has the std rear rack. I assume it has been shimmd up. Also the rear hubs are all GMS, though i thought that GMS Cars used Alcons back in the R32 dats???? (Though im not 100% on that)
I love those rear arms and hubs, and the swaybars etc. So wich i could steal that cradle for my car :thumbsup:
I like both of them...
Go the daggy wheel covers...lol
Great pics mate, do you have any more that size?
Also another vote for the 1990 or 1991 scheme...
Castalloy in SA used to make the the rims. Terry believes that the moulds are no longer in existence if I remember righty.
Ran into a guy who used to work there a few years back, he remembers the team transporter turning up to pick up their rims.
By the way, awesome find.
Cheers
Edited by gtrtech
Terry, Rod and Chris are running 17"Speedlines at the moment.
The Original Castalloy magnesium wheels are past their use by date. Still ok for wets though.
I do like the 1990 colours but it won the ATCC in 1991 colours.
I think 1991 colours look alright as long as you don't run the dark grey wheels like they did at the start of the year.
Apparently that was Alan Heaphy's idea because he didn't like cleaning wheels....or so the story goes...
IMHO 1991 livery, white wheels, and no restrictions.
It was the year they beat up everything :thumbsup:
And Richo and Skaife actually caused quite a bit of panel damage racing each other!
Hooks
I don't suppose you have any more hi-res images like these....?
This GMS doco project looks very interesting. And I love the 1991 'fake' as well. Awesome stuff.
The Japanese do the same with their roadcars.
Edited by ajrichar
 Share
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
