SOLD, SOLD, SOLD
R32,Skyline GTS-T 1992, 162xxxk's
Manual, gunmetal grey, climate control, HICAS, ABS
Frontmount intercooler (ARE GT-R style core)
3in exh, high flow cat,
450hp Turbonetics BB turbo with custom dump pipe and ported exh manifold,
Z32 AFM,
550cc injectors(RX7),
reprogrammed ECU ,
450hp Bosch fuel pump,
450hp clutch (direct clutch in Bris)),
KAAZ 1.5 way mech diff,
King springs (lowered 30mm) with Bilstein height adjustable shocks,
adj Whiteline swaybars,
adj front castor rods (off for road worthy),
adj front upper arm bushes,
front strut tower brace,
17in ROH wheels,
autometer boost and oil temp(not connected) gauges in Greddy A pillar pod, Pioneer CD player(MP3 comp).
tinted windows
tow bar
immobiliser
Included also, original parts (wheels and tyres, injectors, turbo, dump pipe, intercooler, diff center, fog lights, speed activated front spoiler)
$13500 ONO
Located in Nambour QLD
I bought this car in 1999 as a fresh import with about 65xxxkm's. It had an oil and filter change every 5000k's. Recently replaced clutch master and slave cylinders. Looks Sleeper, and have never been pulled over for being 'too low' or 'too loud', but has 268rwhp @ 17psi (potential for more with more boost). I built this car to drift but never have, cause I couldn't bear to bend it. Paint is good (small stone chips and small scratch on front bar).
I'm a newbie here, so sorry if I the post seems amaturish.
Have to sell due to new baby and big dog. Sticking with the Nissans though. Got a Stagea instead.
Edited by Andy D
https://www.sau.com.au/forums/topic/173013-sold/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
