Im looking for some info on clutch options for my car. I want a very streetable user friendly clutch if possible, nothing thats on or off. Got to be able to pull away from the lights at low revs with stalling :-)
My OS Giken sprung centre twin plate is on the way out and was always a dog anyway. So what are the options available ( if any ) that will handle 700 bhp.
Open to suggestions and feedback.
Cheers
https://www.sau.com.au/forums/topic/173015-700-bhp-clutch-options/
we got a 1000hp twin plate from NPC here in brisbane. I cant get over how smooth and light it is. Dont know about retail price brad, if you can talk to kyle about getting one, do that. Or ask him what he thinks about them. We had a sprung centre exedy twin plate before only rated to like 700hp or something and it was harsher somehow then the NPC non-sprung twin plate....weird.
Edited by r33_racer
Hi Brad,
I agree with Daniel. I have a nismo twin in my hack car and its one of the most streetable twins I have ever driven. Its not the coppermix but the model before which is simular design.
The wife can hop in and drive it no stalling !
I plan to get coppermix nismo for my next car.
If you can't get a good price email your mate steve/mayhem. Tell him butters reckons he can get a good price :D
Nismo Coppermix comp twin. Cant beat this clutch should handle that power and doesnt rattle and is as easy to use as a standard clutch....Cant recommend these clutches enough.
Got one of these as well & it's been bulletproof - highly recommended!! Don't waste your $$ on a single plate regardless of brand.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
