Hi Guy's I just bought an Apexi AVC-R and I was wondering if any of you guy's know whats the best place to get it installed and bout how much would it cost?
Also Im saving at the moment for a front mount cooler so I was thinking maybe I should get the avc-r installed after so then i can set a good boost level like 13psi and get a dyno tune, all round the same time.
Or doesn't it matter, just install it now and tune later with the cooler?
Thanks
Mark
:rolleyes:
https://www.sau.com.au/forums/topic/17302-apexi-avc-r/
i dont have a clue aboutmuch when it comes to cars but it aint that hard cause i installed my boost guage, pulled apart the front end of the car and installed the bleed valve.... just follow the inctructions.
https://www.sau.com.au/forums/topic/17302-apexi-avc-r/#findComment-358819
Guest INASNT
AVC-R is a bit harder to install than a boost gauge or bleed valve!
https://www.sau.com.au/forums/topic/17302-apexi-avc-r/#findComment-358834
after seeing it being done its pretty easy.... wiring is too easy. for the solenoid, 1 goes to the actuator on your tarbin and the other goes to the pressure line... in my case, the pressure line was tapped into one of the carbon cannister lines.
when you get it going, make sure you set the duty cycle at aboot 40% so you dont boost to 2bar or something....unless your tarbin can handle it.... :(
https://www.sau.com.au/forums/topic/17302-apexi-avc-r/#findComment-362083
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
    • Oof. Could be worse I guess. I suppose they haven't put any effort into ally suspension parts or CF panels, seats, etc. So they could probably pull about half of that back out of the car. Not like a bunch of other EVs that already have CF everything and roll the scales at ~2t.
