Correct Timing?
What's the correct timing for the GT8 guys? Anybody sure?
My engine bay has a sticker that has some writing in Japanese and "10Degrees BTDC 650RPM" written next to it, yet from everything I've read including the ESM for the G35 - VQ35 Engines have 15Degrees BTDC@650RPM. Just doublechecking.
Cheers.
Edited by -= SKiZO =-
I can't help you at all.
But can you tell me what you think of your car? I've been seriously considering one lately. Since i've now gotten rid of the 34.
Whats insurance like? hows the CVT to live with? is it quick? considernig it's got an early model 350Z engine in it.
I'd go with what was written on the car before what i read some where else.
Yeah me too. The thing is, my engine scanner says currently running at 650rpm at 15Degrees even after resets, and I can't drop the ignition to 10Degrees at that revs. The car does seem to be a bit sluggish accelerating in the lower gears(maybe this is normal) but I thought a good place to start would be the timing.
What does everyone else have written on there engine bay and what car/transmission?
I cant find anything written in my engine bay but I do notice my car is a bit sluggish on acceleration especially from a rolling start and the transmission is in about 4th gear. I find that when I am in manual mode it hoots along when I am changing at 6-6,500 rpm. I think because the transmission is variable other than direct shift it tends to get in to 3 and 4th pretty quickly off the lights even when just putting along.
Cheers.
Just checked my coupe and it's the same 15degreesBTDC@650RPM
Cheers
Bobby
Their are half a dozen different emissions stickers out their and some time they put a VQ25 sticker on a VQ35 engine so be careful.
 Share
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
