  • 4 weeks later...
I have the same problem with hole under my hu. I am making a panel out of metal and covering it in leather and then mounting a switch for an amp and I'm putting the turbo timer in there as well. There are heaps of things your could do.
https://www.sau.com.au/forums/topic/17305-empty-din-slot/#findComment-404603
Well personly i put my h/u in the bottom slot and wacked a stuffed toy in the top slot(chicks did a cute stuffed monkey)but only coz i plan to fill the slot in the not so distant future with a in dash tv and put a ps2 in the glovie......tv's are as little as 300 on ebay now, brand new, 12month warranty, i dont care if its homebrand, as long as the thing works and i can play ps2 and dvd's in my car.......
https://www.sau.com.au/forums/topic/17305-empty-din-slot/#findComment-409534
I went and got one of the pocket insert from Nissan, cost me about $31. Then when i got my stereo installed then next day at JB, they had the same nissan insert for like $20. Oh well.
Its great, got more room to put things, free's up your drink holder.
Only problem i have, when my phone, stereo remote etc are in it, i launch hard at the lights, EVERYTHING ends up in the back seat, lol it looks amazing, everything flys in a straight line, over the center console and lands in the back seat. :)
https://www.sau.com.au/forums/topic/17305-empty-din-slot/#findComment-409937
I just put my a new head unit in(original unit was a double din alpine), and I'm thinking of grabbing some guages, prefably the r32 gtr center gauges. Does anyone know where a good place to get these from. Or even better mayb the original flip front pocket of the r32.
hey raver that's classic man LOL. Should put valcro or somthing in the pocket and some valcro on phone. :-) Mayb bluetack. :-)
https://www.sau.com.au/forums/topic/17305-empty-din-slot/#findComment-409970
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
