Misfiring And White Smoke
but its not using any water... so i dont understand how it could be any water related issues... :lol:
if someone could explain how the water level in the radiator isnt going down and yet its a water seal somewhere, id be more than happy to listen and learn... :cheers:
  • 3 weeks later...
well, checked the injectors out today and no leaking from them...
had a look at the spark plugs at the same time and this is what they look like: (cyl 6 to come soon, but basically like cyl 2-5, ie completely black)
cyl 1: http://www.forghani.net/forum/files/imgp0955_114.jpg
cyl 2: http://www.forghani.net/forum/files/imgp0956_685.jpg
cyl 3: http://www.forghani.net/forum/files/imgp0957_194.jpg
cyl 4: http://www.forghani.net/forum/files/imgp0958_949.jpg
cyl 5: http://www.forghani.net/forum/files/imgp0959_137.jpg
cyl 6:
something interesting to note is that i started her up and let her idle for a while, and its was perfect... not a problem at all...
then i started reving her and it was all fine...
then about 30secs later all the problems came back... misfiring on idle and smoking...
and then this problem stayed even after i turned the car off and let it cool down and then started it up again...
something else to note would be that the smoke is now grey/black... no white, no blue, no green, no purple... just grey/black...
soooooooooooooooooooooooooooooooooo, now that the injectors, fuel reg and fuel pump have been ruled out... what other fuel things can i check?
is it possible that the ecu has a f**ked up idle map but a normal map for anything other than idle?? sorry, i just dont know how the ecu/maps work... :thumbsup:
thanks
ash.
What ecu are you running? (sorry if you already stated this)
Looks like you have a VERY rich idle or even "start-up" that is fouling the plugs. Could also be O2 sensor, afm, afm plug/loom, wrong spark plugs, wrong spark plug gap (try 0.8mm), maybe even coils.
put ur hand over ur exhaust when it does this, get the smell on ur hand. and smell it. does it smell like oil? fuel?
old skool mechanics
my mrs had this civic right, started playing up a bit, blowin a bit of white smoke like this, checked the water for bubbles or oil, checked oil for water, checked comp, checked fuel, it was starting to over heat. everything looked fine., etc. changed thermo stat. etc. then one day.. warp. goes the head. .. was a head gasket, on its way out, just a slight leak and it cooked the head. and didnt give off the usual tell tail signs. only the overheating which was never really bad, only just over half, untill the night it went.
I learnt a valuable lesson that night.... im no mechanic. haha don't know how this will help you though.
but if i took a guess from what you have said, Depending on the smell of the smoke, i would say turbo or headgasket.
well, i'm not too sure...
i was told when i bought the car that it was a skyline ecu that had been chipped by dr drift...
BUT, i took it to a guy who fixed up all the wiring for me as it was a nightmare and he said he reckons its not a skyline ecu at all... its a cefiro one.. :thumbsup:
so i have no idea...
cant be coils as they are brand new splitfire coil packs... spark plugs are iridium plugs (not sure on the gap, but i'll get it checked out)...
doesnt sound like its the afm.. i've heard what they sound like with a f**ked afm, and mine is nothing like it...
it could be the o2 sensor in the dump pipe because at one stage i had raw fuel going through my exhaust/turbo, so maybe the o2 sensor has f**ked itself...
old skool mechanics
definitely smells of fuel and not oil..
the car doesnt over heat at all... and its not using a drop of water at all...
but thanks for the suggestion...
Just know, that a afm that is playing around will cause different faults. Just because you heard one that was farked, doesn't mean all do the same thing.
Your afm could be slightly worn, thus still working but not properly, and may be sending wrong signals to the ecu. I don't know, just saying don't strike it out as a possibility.
I think the misfiring maybe from low cold cranking amps i.e. the battery maybe on the way out, thats if it's not misfiring after say 10mins of driving. Or because of the fuel issue.
The white smoke could be caused from a number things all fuel related, low compression from worn valve stem seals, glazed pistons/bore, worn rings etc. or faulty fuel injectors, junked up, old etc. or incorrect fuel injection timing/duty cycle - if your tune is already rich(safe tune) start up is going to be ultra rich. Try the easy solution first, adjust the screw on the iac valve, this lets the motor run a bit leaner on startup.
cyl 6:
is it possible that the ecu has a f**ked up idle map but a normal map for anything other than idle?? sorry, i just dont know how the ecu/maps work... :D
thanks
ash.
Black smoke also fuel related. I don't know how you could rule out injectors without taking them out... Trying running some injector cleaner through the motor.
you know what... after about 10mins of driving it does actually start to clear up...
i dont know of this IAC valve, but i'll do some searching...
well, i just ruled out that the o-rings on the injectors werent faulty cause it doesnt leak fuel into the engine... what you're saying is right though... i cant fully rule them out unless i take them out and get them checked... but i'll try some injector cleaner first....
thanks for the info... :D
cya
ash.
  • 3 weeks later...
just to finish off this thread....
the whole problem was a simple fix... it was running the wrong ECU... it was running a cefiro ecu instead of the skyline ecu...
and the mechanics i've spoken to cant explain to me why it was running fine and then over night it f**ked up...
either way, i dont care.. its fixed...
thanks for everyone's suggestions... :(
 Share
    • There are a few variables here, some are relevant but not critical (IMHO) to help answer your question. The two major things: 1) Ignoring anything to do with forced induction - all engines have their own natural torque curve, and it will ALWAYS roll over higher in the rpm.  There is a fixed relationship between power and torque.  When dealing with kw and nm, the relationship between them is roughly: kw = (rpm * nm) / 9549 nm = (kw / rpm) * 9549 The peak torque of an engine (without boost) will typically climb until somewhere nearish the middle of it's operating rev range, give or take a bit - then start dropping again.   The nearer the minimum and maximum rpm of the engine the steeper that drop off tends to be. 2) Boost simply increases the density of the air going into the engine, which inflates the torque at that point.  The ramp up in the torque curve you see on a turbo engine is due to the boost rising, but it's essentially just multiplying the torque you'd see if it was naturally aspirated.  The roll over you see at the end will typically be what would have always happened with the engine, whether it was naturally aspirated or turbocharged.   If the torque never started dropping then power would climb infinitely. The cool thing about this is you absolutely can tune the power delivery to suit the needs of the owner and/or the limitations of the car, and I regularly do this.    With modern turbos we've got to the point where a setup that someone may run well over 20psi of boost with could actually reach target boost well under 4000rpm if the tuner/owner WANTED to - and a lot of people seem to do this when there is actually no realistic benefit, generally it just adds a massive amount of strain to the engine and drivetrain and often actually makes the car harder to drive. As a general rule I tend to tune the boost curves for cars I tune to reach a "useful" torque level through the rev range and will often end up with a curve that ramps hard to a point, then creeps for the rest of the rev range - not to make the boost curve "soft" as such, but more to make sure its neither laggy nor pointlessly violent in it's delivery.   There have been cars I've tuned to be almost like a centrifugal supercharger (or naturally-aspirated-ish) where they actually only hit like 8psi of boost before opening the gate, then ramp up the next 10psi over the rev range... if the car is "loose enough" to drive. On the flip side I've tuned a car that had stock cams and the engine's natural torque curve fell over HARD in the higher rpm and resulted in a slightly awkward power curve to work with, in that case I actually started ramping up boost to boost torque in a way to offset the engines "NA" torque drop off... at peak rpm actually running a good 5psi+ more boost that what the "flat curve" would have defined.  This gave the owner an extra 500rpm or so of useable rev range, and had a fairly solid impact on times he was running at motorsport events due to being able to hold gears a bit longer and also falling into a more useful part of the rev range in the following gears. Here's an example of an RB in a GTSt I've done the "softened" boost curve to not pointlessly ramp straight to the max boost target early in the rpm, but still made sure it builds useful boost.  If you went in the car you'd not guess at all that the boost curve was doing anything "weird", it feels like it spools immediately and accelerates relentlessly (traction dependent) and holds to max rpm.   I don't know if you'd guess what the boost curve was doing by driving the car, or even looking at the dyno plot... but imho it suits the combination.
    • therefore on the first examples, as we see, changing cams (graph 2) influences the quantity of torque at high revs its OK for me. so a tuner can act on the wastegate via the boost controller to increase the boost at high revs? on the last example, the boost does not decrease ok, but the torque does. this can come from cams etc etc ok. but on the other curves the boost is not constant, it increases, this is what I find strange to my mind. even more so if it comes from the relief valve. sorry I'm very new don't blame me. in my mind I couldn't imagine how the boost could be higher after the spool
    • right, but fundamentally, for a given mechanical setup, you are either using all the torque (and therefore power) it will give, or you are choosing to run it less efficiently. Many tuners will have a practice of identifying peak available torque and then winding it back a couple of % for safety, but unless you are working around a very specific issue like a weak gearbox, there is nothing to be gained by making 20 or 30% less than the engine can
    • You can manipulate the torque delivery by ramping in boost gently, then throwing it all in after peak torque to keep the torque flat. It's nothing magical.
    • Tuning the wastegate to do it. That is all. Most people want the boost to not fall off like the most recent example. Those also look like dyno runs with an Auto/Torque converter setup, which does fun things to the graph. The boost tapers down like that because the turbo cannot supply the same amount of air at 7000rpm that it can at 3000 in terms of PSI. That, or the tuner has decided that it tapering off like that is what someone chose to do. IF you have a wastegate that can't bleed enough air to slow the turbine, and IF that turbo can flow enough air to feed the engine at high RPM, you get 'boost creep' which is a rise of boost pressure beyond what you are capable of controlling and/or want. None of these show symptoms of that, but if you had a run that was 20psi at 3000rpm, and 27psi at 7000rpm, it could be an example of that. Or simply that the person wanted boost later for their own reasons... The dyno graphs don't always show the full context.
