Guys,
Anyone used a linear oil cooling line?
Which is basiclly a aluminium pipe with oil line fittings in each end and machined groves down its length mounted under the car. Used in nascars i am told rather than normal oil to air coolers.
https://www.sau.com.au/forums/topic/173067-linear-oil-cooler/
where do you run the line?
it's the exact same principle as a radiator style but just finned on the length by the sounds of things.
if you were really clever you could determine the surface area of either type and see how much heat dissipation you'll get out of both...
LOL not that clever saddly.
I tried to get a pic but no luck yet they come in 3, 4, or 6 foot lengths and have about a 3/4 inch bore and about 1 1/2 OD.
My thoughts were to get 2 of the 3 foot items and install them into a aluminium header tank and turn them into an oil to water heat exchanger by running the coolant from the engine into this headertank whick is about 90 degrees on outlet of the engine. The oil would pass through this first then onto the 2 air oilcoolers before getting involved with the up and down bits. And hope fully get over this oil temp issue for good.
I found that running my fuel return through an aluminium pipe back to the tank has worked well as fuel temp has dropped about 10 degrees ( measured on the black swirl pot )
Edited by tacker
all sounds like a bit over overkill to me, for what reason can't you use a normal air to oil cooler? Don't the RB26 engines already have an oil to water cooler as part of where the pressure sender/filter bolt up to the block.
I do like the aluminium pipe for the fuel return line though :D
Nope dont think its over kill!
My version of over kill is having to do track sessions in 43 + degrees (without killing engine). So hot now we have to do night session under lights.
Yes RB26 do have an oil to water heat exchanger, but even with 2 x oil to air coolers my oil temp still bumps 120 degrees. Will also allow another 4 litres of coolant which will give the coolant more time out side the engine which can only be a good thing.
Guys,
they are nowhere near as effective, great for fluids which have a low density like fuels etc but i used one for pwr steering a while back but it did not cool anywhere near as much as a stack type cooler.
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
