hey all.
happened yesterday and today.. theres something howling when driving for the first 2-3 mins.
i normally warm my car up for about 2-4 mins.. the oil pressure drops from about 7bar to 4 bar and th revs dropped a bit.. like normal.. and i drove off.. careful not the get the boost gauge newhere close to 0.. shift at 1500 or so..
yesterday it howled abit more.. cos i didnt let it warm up.. only like 2 min warmup. this morning was kinda intermittant cos i let it warm up for jst about 4 min.
im sure its not a leak as we tightened the fmic piping up properly.. i double checked it when i got home on the day of the install.
it boosts fine tho.. no lag etc.. only happens when the cars coldish..
any input on what the noise could be?? kinda has me worried as the cars only done 85xxx k's and im the first owner.
My mods:
Full exh
6*3*80 HDi FMIC
Apexi Powerflow
Factory boost solenoid (low - 7, high - 12-14psi) NOTE: i HARDLY use high boost, if i do its only for a few seconds then flick it back to low.
i hardly boost my car. no really.. i hope its not my turbo but something tells me it is.
https://www.sau.com.au/forums/topic/173073-turbo-howling/
NOTE: it is also getting very cold here in auckland. im talking below 10degrees cel. it must hav been about 2-5 degrees yesterday and this morning..
my mate thinks its the vortex thing happening with my powerflow filter? going to check for shaft play after work today. fingers crossed!!!
https://www.sau.com.au/forums/topic/173073-turbo-howling/#findComment-3183070
Howling probably isnt the best description... hmm..
Does it do it on idle if you rev it?
Or only under load?
Where is the noise coming from, right/left side of the enginebay?
Anything you might be able to provide will make it easier.
It sounds like a leaky cooler pipe to me, but everyone describes noises differently :D
https://www.sau.com.au/forums/topic/173073-turbo-howling/#findComment-3183225
i vote for exhaust gasket leak, without knowing the definition of "howling".
common issue with the lock tabs not working or breaking on the turbo flange bolts. But some answers to R31Nismoid's question will help the diagnoses.
https://www.sau.com.au/forums/topic/173073-turbo-howling/#findComment-3183824
cheers so far guys.
it only happens when i drive it in the cold.. its been around 2-5 degrees here lately so blooody cold.. thats it.. only for a few mins.. i checked all the fmic piping again last night.. all tight..
i doubt its the exh mani tho cos i never touched it..
i checked the turbo wheels for shaft play and it seemed sweet.. no play at all.. to be oversensitive, id say the bearings were a weee bit noisy but thats it.. i cud hear it when i spun the wheels with my fingers.. it boosts fine.
https://www.sau.com.au/forums/topic/173073-turbo-howling/#findComment-3184245
+3 to turbo gasket leak.. after putting my big front pipe on and having to perform some percussive maintenance on the dump pipe bolts.. take car for drive at over 5000rpm it sounded like there was a banshee under my bonnet. Tightened all turbo>manifold bolts and the banshee died :D
https://www.sau.com.au/forums/topic/173073-turbo-howling/#findComment-3184866
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
