Hi all,
Need to get rid of a few things clogging up my room.
First up a 10 inch Clarion pro audio sub (i think its rated to 250W) in a carpeted, tuned ported Aeropro box. Very good condition, a bit dusty in the pics. Box was $150 itself new.
$150
$130
NOW $90 ONO
Next up is a Clarion V-net 4 channel amp, rated at 4x50 Watts RMS.
Good condition, but has a circular scratch on it where a spring from my car seat used to rub on it (was installed under my drivers seat in my old r31). Needs a wipe down as is pretty dusty after sitting in my room for a while. Otherwise works perfectly. Was used with rear channels bridged to power the above sub, whilst running 6.5 inch splits off the front two channels. Sounded good IMHO.
$120
$100
NOW $70 ONO
Or if you want to take both I'll do it all for $200.
Selling because I'm not doing the audio thing with my R32, happy with just a headunit and speakers.
Pickup is from North Melbourne, Vic or can be arranged with enough notice in Mt Martha 3934. Postage not a viable option, as both items are really heavy.
Any question please just ask, I'm on the forums every day. Bigger res pics can be emailed if required. It will all be going on ebay if not sold in 2 weeks.
Thanks,
Rhett
Updated with lower prices.
Its a cheap way to get into car audio, just add some 6" splits and you've got a good solid system.
I will be in melbourne on the 24th of next month, if the amp is still there on that date ill take it :ninja:
PM me if it is - cheers
hmm i think i mite take em
im in melb
western suburbs
but 200$ cant go wrong
hmm pm me
Mate tried to pm you a while ago, not sure if it worked.
If you are still keen pm me or call me on 0404021495.
Same goes for anyone else still keen.
I've checked out postage for the amp, it is about $15 to Sydney to give you a rough idea.
The sub and box is way too big and heavy to post sorry.
Cheers,
Rhett
Cheers,
Rhett
ill take the amp if its still there!
im in melb..
pm me asap
  • 4 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 5 months later...
Hey does anyone want this stuff? I've still got it, however now I live in North Melbourne
$90 ono for the sub
$70 ono for the amp
will do a deal for both
  • 10 months later...
Wow this stuff is still sitting in my bedroom a year later.
Does anybody want it? Make an offer.
  • 2 months later...
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 馃槢   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
    • Oh nah, S55 doesn't eat bearings, just the crank hub slips lol.
    • When鈥檚 the tow ball on the 33 coming? 馃檭
    • I welcome any basic question that can help haha. Yes it has 2 unis but the driveshaft is a one piece and the unis are welded without a slip yoke at each end.   What's funny is anytime I've ever had wheel vibrations it's always been in the front so I automatically assume it will lead to steering wheel shake and not chassis vibration. With that being said, I never considered looking at my rear wheel balance... I have doubts though as this wasn't an issue before I pulled the motor and trans but is still very much worth a look. I'll do that tonight after work. Thanks.
