Ok. I just lost reverse gear on my car (1990 gts4, rb25 motor). Had a search couldn't find anything. Reverse out of the garage fine, then couldn't get it in at the mall. Which made stuff interesting. Anyway, did a search in this forum, couldn't find anything. Been told the gbox has an aftermarket gearset in it. Every other gear is fine. (has a heavy duty clutch). Almost like reverse doesn't exist anymore.
Anyone able to provide any advice or info? Would be appreciated.
https://www.sau.com.au/forums/topic/173104-lost-reverse-gear/
  • 3 weeks later...
  kiz_baby said:
I have the same problem but on an auto transmission. Have you sorted this out yet as I have absolutly no idea
we had that problem with our old accord - auto too - wouldnt reverse when its cold, but once warmed up it reverses - we had to get the auto box reconditioned....now its fine. Expect it to be around the $1,500 for a recondition
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
