So things have changed and i have to put the old girl up 4 SALE a lot earlier than i planned too :D
Details:
Modified FC, 186, extractors, 4 speed Aussie box, 308 diff, HR front end (drum brakes), 7inch torana chrome wheels with new GT Radials, 11months rego, 2 speed wipers, heater/demister set up, stereo & immomboliser, fresh tune up and is running great.
Also have some other spares that can be negotiated on with price.
Car is clean but not 100% perfect but very nice to drive and goes well.
Car is located in Tassie but willing to send interstate at buyers expense.
$6800 ono
Please reply here, or PM
Cheers GMB
https://www.sau.com.au/forums/topic/173111-59-fc-special/
  • 4 weeks later...
  • 5 weeks later...
  • 3 weeks later...
BUMP
car has rebuilt carby and new manifold gasket. Worked 186 build has began and awaiting on head gasket and straight cuts :)
Will be going into spray booth in the next few weeks to be sprayed in 59 colour scheme :D
Cheers GMB
https://www.sau.com.au/forums/topic/173111-59-fc-special/#findComment-3322759
  • 5 weeks later...
  • 3 weeks later...
  • 5 weeks later...
Could squeeze it in the back shed...maybe
Do you have current pics with all the work you said was in the process of being done completed?
It's a nice time of year for a trip to the apple ilse.
PM me if you'd prefer to email the pics.
https://www.sau.com.au/forums/topic/173111-59-fc-special/#findComment-3506007
Didn't end up spraying it as other things came up.
Interior and other pics here.
If you would like any others let me know :)
Cheers Ben
https://www.sau.com.au/forums/topic/173111-59-fc-special/#findComment-3508219
i dont understand?
you are selling the same car in a different forum for $3000
http://fefcholden.org.au/forum/index.php/topic,11396.0.html
Whats not to understand, that was an old 4 sale thread that has since been closed, it was 3k with the car not running (motor had blown head gasket and wasn't included in sale) and i was after a quick sale as i needed the cash as i was interested in lathe machine.
If you look at the very top of that page you will see the new listing with car running again and same price, as it is on NS, BC, Holden car parts and Tas cars.
You show me another FC in this condition for 3k, YOU WONT FIND ONE!!!
https://www.sau.com.au/forums/topic/173111-59-fc-special/#findComment-3553723
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
