Hey SKYLVIA,
I was after getting the same done to mine. I went to Quickfit in Fyshwick the other day and was quoted $230 a piece for respraying and getting the gutter rash sanded out. Was told they would be brought back to new condition. I'm about to get a quote from 'wicked wheels' which is a mobile type van that comes to you so will let you know what price I get from them, but to answer your question it can definately be done. Don't know how well it would go if you tried it yourself though.
https://www.sau.com.au/forums/topic/173116-gutter-rash/#findComment-3183386
I had Jax Fyshwick repair my Volks, they did an excellent job - Respray, re machine (for gutter rash) and they even left the Volk racing sticker on it, all I had to do was say that I wanted to keep the sticker - all for only $225.00 per wheel.
I highly recommend that you go see them.
https://www.sau.com.au/forums/topic/173116-gutter-rash/#findComment-3192485
So I take it you can drop off the wheels to them and they'll do the lot? Ie the tyres can be on the rim?
Yeah, I had tyres on my rims when I took them in.
They'll take a day or two to do them so its best if you drop them off.
https://www.sau.com.au/forums/topic/173116-gutter-rash/#findComment-3192690
    • Hey lads just finished tidying up a gtr a bought. Originally from Sydney now living in New Zealand
    • Hi Guys, Looking for this piece if anyone can help out.   https://tfaspeed.com/products/nissan-skyline-r33-gtr-rear-trunk-finsher-panel
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
