Hello. Here is a permanent solution to fixing those faded skyline headlights. One of my mates from tafe inspired the idea.
Pretty much I was sick of polishing my lights every 3 months after the plastic oxidized itself again.
Here is a pic of my car with the dull look headlights
If you are going to DIY this I would recommend some previous spray painting experience and also good safety gear like a respirator and good ventilation (preferably a booth of some sort). If not take the lights to a paint shop, I can’t see it would be very pricey to do a small job like this.
Here are the materials I used
Plastic Primer
Antistatic plastic cleaner
2 pak clear
2 pak hardner
2 pak reducer
2" masking tape
1 bucket of water
Sponge
truckwash
1000 grit wet and dry sandpaper
Tools used
3.5hp air compressor
1.4mm spray gun
Screwdriver and socket set
1 - Ok first of all u will need to remove the grill (held on by a few clips) then remove the headlights (few bolts on the rad support and 2 small screws underneath)
2 - place the headlights on something stable, fill a bucket with water (and a dash of truckwash if u like), soak a sponge in the water and run it over the headlight plastic while sanding with 1000 grit paper until the whole light is a fine haze of scratches.
3 - Dry the headlights off, use a clean rag and wipe over with the plastic cleaner.
4 - Mask around the outline of the headlight (not totally necessary, just me being fussy) use an airblower to remove any dust from the lights.
5 - Pour about 100ml plastic primer into spray gun and place a light coat over the lights (allow a minute or 2 to dry)
6 - Mix up the clear. the one I used was 4 parts clear, 1 part hardner and about 10% thinner. Now spray a light coat over the lights (just enough to make the lights look clear)
Allow a couple of minutes for coat 1 to tack off and put a final coat on (so the finish looks nice and smooth)
Give it about a day to dry hard, fit them back up to the car, and never have to polish up dull lights again :thumbsup:
Edited by Sambo33
https://www.sau.com.au/forums/topic/173132-fix-your-faded-skyline-lights/
I'd like to see how they go after a few months in the sun.
I thought the plastic broke down with UV light, which caused the hazyness. If that's the case, a clear coat of paint may not stop the UV from reaching the plastic, and may still breakdown the polymers...
Trav33 ive had this on my car for about 1 year now, no more dull headlights :thumbsup:
thanks for the comments guys!
i think my lights may have been worse than most, i previously used farecla medium grade cutting compound on a machine buff on my lights. After about 2-3 months they were yellow and dull again.
DrewII - i get some moisture inside my lights sometimes when that car gets wet, but it evaporates away. the yellowey dull look is only on the outside of the plastic.
I guess to turn the lights yellow you need oxygen too .. this fix restricts oxygen from the plastic so the yellowing does not occour?
Im confused how you got from a dull faded smoked light to such a clear one? U just sprayed over it with clear and it make the cloudyness go away?
How does that even work? Did you not cut back the plastic to remove bemishes?
Edited by DECIM8
yeah mate, the pics of the headlights on the stands where they look all dull.. those are fine sandpaper scratches. wet-sanding the lights cleans all the tarnish off, when i was rubbing them down i could see all the yellowey stuff running off them.
the stock plastic cant stand up to the effects of weathering, the 2k clear is essentially a type of plastic. so im reinforcing the plastic.
ive used this particular clear on some of my cars before and it can take weathering fine, no drop in gloss, no yellowing.
hope that makes a bit more sense :thumbsup:
you should run a headlight exchange business!!
i would love to do this, but am afflicted with accute laziness and lack of a compressor :thumbsup:
thats not a bad idea :cheers:
i would do it if i had a better facility and a bit more time.
Excellent cheers and does it scatter light at all or disipates light as original?
nope, no different. the clear film build would be similar thickness to an a4 sheet of paper.
Nismo_God - No worries :thumbsup: my method was a bit thorough, but it can be done easier than that.
  • 2 years later...
cool man glad you tried this out ive thought about it before but never got around to it.
i just p1500 then p2000 mine and polish them up with farecla g3 and they have been clear for about 4 months now but looks like a clearcoat would be a permanent solution. anyone in adelaide wants this done hit me up lol
Edited by TWINS33
  • 8 months later...
hey man i kno this thread is dead but does the offer still stand about the polish and clear in lonnie? i would pm ya but im a n00b with less than 10 posts.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
