  • Replies 78
Ok So its on this wensday night? ive been a few times with my dads mates watchin them run there cars but never actuly gone for a run ? whats the price and what do i need to bring apart from my car helm and some balls. :D
https://www.sau.com.au/forums/topic/173135-wsid/#findComment-3184580
Hmmm might consider going down this week, gonna strip out the passenger and rear seats and see if it makes much difference.
might get off my ass and fit the oil cooler and change the oil to get ready for SAU trackday.. man.. so lazy..
https://www.sau.com.au/forums/topic/173135-wsid/#findComment-3184864
hey ray,
i dont think im ever going to go to those lengths....way too lazy to take out the seats just to put them back...
u heading out to wakefield? u racing? im heading out in sept so i thought to give this one a miss....
have u seen what i did to those T1r's? had a little fun on them....regretted it almost instantly...
https://www.sau.com.au/forums/topic/173135-wsid/#findComment-3184978
Yep SUPPORT SAU and heading out to Wakefield on July 8th or 9th can't remember.
Yeah... kind of tight on cash these days wanna see how close to 12 flat i can get with the current setup resorting to all measures without breaking anything haha
then camshafts will go in and get me a HIGh HIGH 11 hopefully but we will see..
taking advantage of the weighing bridge at WSID :thumbsup: last time the whale weighted in at 1376kg with 1/4 tank of fuel full interior less spare tyre/jack/tools.
LOL i read about your T1R's and SKidpans days. i saw it coming good work rofl
https://www.sau.com.au/forums/topic/173135-wsid/#findComment-3185436
    • My EFR 8474 Black, made 800awhp on a roller dyno. at 25-26psi. E85. Shaft speed was around 106,000rpm 1.01 rear. The rear is maxed.  6 boost Turbosmart 60mm gate 3.5inch exhaust  Head is worked to the shithouse. Bain racing. VCam. 272 exhaust. RB28 - RB26 foundation.  You have an intake issue. Start getting proper data and I mean go back to the simple things.  - Pressure test your intake - Block off the Turbo BOV, you don't need it.  - Test pressure before and after your intercooler If your head is pretty stock, that is your issue. Especially if it is NA.  Take it off and spend $10k on it.
    • Temp = -21.052 X Voltage + 114   That should get you pretty close. Calcs based on two points I could do easy calcs on (30 and 70 degrees).   It also says your sensor should only read as low as 9 degrees when it maxes out at 5V, and should hit a peak of 114 degrees at 0V... Just as a heads up if you were going really cold places, or wanting to be aware when temps really go up with it.
    • you, sir, are a prince. good on ya.
    • You're not wrong but 5W30 at 100C is like 10 cSt vs 25 cSt for 10W60. If we think in terms of viscosity margin 10W60 will probably still be ok at 130C but 5W30 is probably too little. It's absolutely shocking how hot the oil gets in something like a stock FL5 from only ~3 minutes of use on the Nordschleife. I would not risk taking a car like that to anything remotely intense without a ton of work done for cooling. Heat shielding on the manifold/turbo/downpipe, oil coolers, etc.
