hey guys
i got a 1990 r32 gtst and have just had the slave and master cylinder for the clutch re-sealed or wateva u call it. i had this done cos the car was shuddering getting into gear....it fixed the problem.
BUT now i've noticed drops forming on the garage floor under the car. The engine under tray is fairly damp with fluid to. i have cought some of the drips and they are oil drips and are a fairly clear fluid....and the flutch fluid that was put in was also clear...
i have noticed that in the clutch resiovoir in the engine bay it is filled to about 2-3mm over the max line....so do u think the drips are from this???
the drips are dropping on the passenger side of the car so not directly under the clutch resoivoir at all....got me stumped!!
is some seal maybe bust around the box area or something???
info here would be very much appreciated as i havent had any drips before
i'll stop writing now..hehe
Edited by WAN73D
https://www.sau.com.au/forums/topic/173149-some-sort-of-oil-leak-under-car/
Thanks SECUR1TY for the idea but i just checked the power steering resiovoir and its sitting right on half way on the dipstick which to me seems quite healthy ....for a skyline haha.
any other ideas
i have noticed that there is a bit of an oily surface on top of i what i think is the clutch assembly. like if u look into the engine bay from the passnger side ...at the back under the engine block...this surface is always oily even when i clean it with a rag a new layer forms after driving...
hmmmm.... just wondering if its leaking down from here somewhere onto the drip try.
well the only other thing i can think of that would cause oil to build up there is:
- the cam cover gaskets - you'll need to take the cam covers off and replace the gaskets and half moons.
- rear main seal - gearbox off, rear main seal housing off, replace rear main seal.
- gearbox - nfi, just an idea.
dont just check the reservoir. get under the car and check the actual line leading from it as well as the PS pump.
In my 32 it looked like a rear main as the oil was dripping from the bottm of the gear box, but it was really running down the side of the motor/box and dripping off the lowest part.
I replaced the cam covers and half moons at the back (next to the fire wall) and problem solved.
thanks for the info mate
yeh its no so much dripping from directly under the rear main seal housing tho. so it seams to be dripping and then running down to fall our of the lowest point of the under tray (catch tray), but perhaps yeh it could be the cam covers and half moons and its just running down to this point
one thing is tho that the oil seems pretty clear and thin...where as i would of thought oil coming out of the cam covers would of been more black and thicker...
just as a note how much did u pay do get ur cam covers and half moons done the??
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
