Hey guys i have been looking for this V power racing fuel for a while now and the car definately runs better.
Thought i would share the location with others if you dont already know.
Northside of Brisbane - Shell Sangate Rd Virgina.
If anyone else knows of other locations list them here :thumbsup: .
https://www.sau.com.au/forums/topic/173152-v-power-racing-fuel/
  • Replies 47
How much per litre Sub?
It does look to be the fuel of choice. Have you read the article on the MoTeC site: http://www.motec.com.au/fueltest/index.htm
I know a few track day guys who are switching to it.
Yeah interesting facts, some good info. I actually saw that episode on the testing and since then have been looking for it.
Finally found it thanks to my old man who found it by mistake.
Thats why i think its good to list other locations for people who have been looking for it.
The car runs alot better.
i got some of this at the shell on hawthorn rd, brisbane yesterday i was surprised to see they didnt have any normal premium in there, well not that i saw anyway. (didnt look to hard though) payed $1.44.9
Is that the first time you have used it, did you notice a difference.
hmmm i always favoured shell stuff (optimax prior to v power) cos that's what they use for the v8 supercars (shell makes them one big batch at the start of every season and they all draw from the same batch to keep things stable) or at least they used to.
so when i bought my skyline (all of about 3 months ago) i took it straight to shell and filled her up and she felt great. but then the second tank felt like shit. so i switched over to caltext vortex with mixed results.
maybe i'll give shell another go....
edit: are all v-power's 100 octane?? i think, but can't be sure that the one i used was 98??? Hungry Jacks over the highway from mudgeeraba on the goldy if anyone knows.
Edited by made_guy
Today i payed $1.45L i think thats a fairly stable price as normal fuel was only $1.16L
yeah it is a bloody good fuel but i refuse to pay for them now...the price used to change as the pump price changes, but now because the market is so special, no matter how cheap the normal petrol is, the price for v power racing will be set at 145c per litre...rip off if you ask me..i can stay on V power untill the special occasion comes
to add the location,
Shell Albany Creek ( on the way to Mt Glorious :sorcerer: )
Shell on Coro Drvie neae Wesley Hospital
and yeah the fuel is great for my car been running on it for 3-4 months straight, only just came off to v power and already notice the diference..
the ethanol is good in a way, as it cleans everything in the engine as it gets passed through. Its almost as good as having water injection except its in the fuel. However because its partially made up by ethanol the fuel isnt as dense and it also burns leaner, so when being tuned it needs to be richened up abit in comparison to normal fuel. By all means you should get a little less economy from a tank because of this. However it does have a higher octane rating, so it sort of works itself out. Think of it like methanol, it burns lean and cold, thats why you need to squirt 2.2 times as much over std fuel. But the octane rating of it is astronomical.
Thats how i see how the ethanol helps, whether its right or not is beyond me.
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
