I took my R34 to Top Racing about a week and a bit ago.
Paid them to install an Avcr and SAFC.. I had already done all the wiring for both, but paid for the loom etc to be put through to the engine bay and the solenoid and pressure sensor installed. AND THEN A TUNE
I figured paying for it meant less effort for me.. too lazy :thumbsup:
anyways..
they said the solenoid on the avcr is busted. and they could only tune the safcII on 6psi factory boost.
Told me to get another solenoid and then they can retune it
Anyways a week and a bit later i went through the whole install myself. shortened the run of vacuum hose and relocated the pressure sensor to a different location as the book said keep the hose as short as possible. I also ran 12v over the solenoid... it make clicking noises... AKA...it was WORKING
thats all i changed.
then i went through the avcr itself. vehicle settings were correct.
but the main thing... THE SENSOR SETTING was wrong.
once i set that.. the solenoid was ticking away happily and the boost reading was coming up nicely on the display etc.
perfect..
So my question is..
Do i take the car back there and ask for a retune on higher boost FOR FREE as they did not install the unit properly.
I feel like this is the right thing for me to do. I paid for 3 hours worth of labour and then an hour of tuning.
for an install that wasnt done properly in the first place..
any advice.
https://www.sau.com.au/forums/topic/173154-top-racing/
I would think, that if you pay for the job you are entitled too ask them to tune the ebc for free, as they were incorrect not you. And im guessing they would have tune the ebc at the same time they tune the safc so the cost of tuning wouldn't have increased.
I would say your best bet is to go down and talk to them in person and see if they are willing to fix the problem
Cheers Michael
https://www.sau.com.au/forums/topic/173154-top-racing/#findComment-3183762
aaah good.
this is my intention
I really wanted to check if it sounded unreasonable.
I went there because of all the positive feedback so i hope they will come to the party.
anyways in the meantime i fried the headunit of the avcr.. plugged it into the safc plug.. complete noob thing to do.
sooooo.. anyone not using the headunit for a day i would like to rent one for the tuning...
I am happy to pay someone to use it for the day
so if anyone is a weekend warrior and not using their line for a day or 2.. drop me a PM.
1 more thing... Who actually does the tuning at Top Racing.
oh and HIPSI....crossed my mind SO SO SO many times.. but seriously.. these guys get a great rap on this forum.. and this is why i went in the first place. My requirements are simple compared to the types of machines people need tuned. I reckon they will come good
https://www.sau.com.au/forums/topic/173154-top-racing/#findComment-3184136
no point using someone else's AVCR to tune it, as when you unplug it, it wont be controlling the boost, and doesnt the control unit store the settings anyway? thus erasing the owners settings, and you will need to get it re-done when you get yours fixed/replaced.
https://www.sau.com.au/forums/topic/173154-top-racing/#findComment-3184182
if the AVCR, is like any other ebc, there will be only a few settings (4 if i remember correctly) gain etc etc...
You can just write down those values, get his car tune for the higher boost (copy down the values for his boost setting) then just give it back and put the old settings in
https://www.sau.com.au/forums/topic/173154-top-racing/#findComment-3184201
If you have blownen up one head unit, that does not give anyone good confidence to lend you theres!
There is only a few main settings on the AVCR, but the self learn mod sets about 10 points per boost setting and people will use at least two boost settings, so it not realy a simple fix.
https://www.sau.com.au/forums/topic/173154-top-racing/#findComment-3184456
yeah i know... the confidence..
if its a plus.. the safcII is plugged in safely.
leaving only 1 spot free for the avcr... *CHEEZY GRIN*
hahahaha
Michael is on the case so I will retract the request for borrowing.
I will have a replacement head unit shortlyish
then its off to top racing for a negotiation
anyways on a brighter note... when the avcr did work before i decided to relocate it... car was super happy.. i completely forgot the rush of boost from my old series II
the 34 tiptronic is so smooth and linear that i forgot what i was missing..
higher boost is the new black right now
https://www.sau.com.au/forums/topic/173154-top-racing/#findComment-3185051
for the record, that was mitch that posted under my name.. I have no idea what an AVCR is :worship:
https://www.sau.com.au/forums/topic/173154-top-racing/#findComment-3188329
id like to say good on you, because you came on here and was open minded and aked and question instead of one silly little thing going wrong and you tarnishing there name and with that attitude (as steve has shown) they are more than happy to help you out!
https://www.sau.com.au/forums/topic/173154-top-racing/#findComment-3193118
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
