HR31 coupe unfinished project
Hey all this is for sale, thought i could get cash to keep it but i cant.
HR31 coupe:
Interior:
Standard interior (seats etc)
Greddy boost guage
Jvc headunit
Pioneer splits in front
Pioneer splits in rear (no tweeters or crossovers)
2x10'' Sony subs in boot with amp
Exterior:
Needs a respray of boot, roof and bonnet at least
15'' mags with 225x55x15's all around
Brand new genuine Nissan front bar with no vent cut out
Have original front bar and new cooler vent also has lower lip on bar
Taken spoiler off to get holes welded up, but holes has silastic over them at the moement
Dark blue color, with a green pearl
Engine etc:
No engine in car at the moment
Have RB20 silver top in garage waiting to go in
Rebuilt turbo (has steel exhaust wheel) have been told its a older HKS item, has had a FULL rebuild
Have two engine looms for the silvertop
All it needs is a AFM from a 32 skyline
R32 manual gearbox, just been rebuilt about 5000k's ago (did a change over from orignal box)
FMIC installed, no piping at the moment (have universal piping kit in garage)
Exedy h/duty clutch brand new and flywheel just been machined
2x Nics motors (you can have with car for free)
Water pump and timing belt has just been done on silvertop (have a spare genuine nissan water pump and gates h/duty timing belt as well)
Spare clutch and flywheel from silvertop
Genuine Nismo h/duty pivot bolt in g/box
Genuine Nismo braided clutch line for the clutch slave
Silvertop has 132xxx k's on it (not boosted or thrashed, came from a auto R32 4-door)
Suspension etc:
Brand new KYB all around
R31 House subframe and sway bar bushes (not installed just yet)
HR31 100mm front struts installed with Endless pads (have brand new ebc greenstuff pads as well)
Front rotors are brand new DBA slotted type
Spare parts:
Centre console (thing inbetween driver and passenger)
Spare set of 15'' rims w/out tyres
2 nics motors
Silvertop turbo
Nics turbo
2 pairs of calipers with the 98mm spacing
Heaps of other crap i cant remember
Price: Looking at around the $5000 mark ono
Ph: 0439481838
pics at: http://s43.photobucket.com/albums/e357/gaffa20882/
thanks
https://www.sau.com.au/forums/topic/173166-hr31-coupe-unfinished-project/
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
