i mean i allredy have the lock bar in place and lines blocked offi have a 2ws pump and want to take off the 4ws pump as it is massive and i dont need
just wanting to know if anyone has done this what was needed to be dont and how hard was it
https://www.sau.com.au/forums/topic/173243-2-wheel-steer/#findComment-3186911
r33 or 34 pump and bracket should just bolt up in place of the 32 unit.
belt will be 3 ridge rather than 4.
The lines will be the tricky part, i can't confirm that the the 32 lines will bolt up to the 33 or 34 pump. You will probably need to do some custom for the pump outlet and block up one of the return lines on the reservoir (or get a smaller r33/s13 spec one.
https://www.sau.com.au/forums/topic/173243-2-wheel-steer/#findComment-3188135
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
    • That link was very helpful thank you.
    • That is the option code, not the VIN. Regardless all of that production is considered series 2: https://gtr-registry.com/en-ecr33-vin-table.php
