Service Part Numbers
Anyone have part numbers for replacement things like oil filters, fuel filters, etc.
...and not stock part numbers, i mean aftermarket parts like valvoline filters and the like
feel free to post in here so we can all do our own oil changes!
cheers,
Warren
Quick run down is,
Air filter A360
Oil filter Oil filter: Z445 (3.5 L) or Oil filter: Z436 (3.0 L)
Fuel filter OEM only 16400-2Y505 OR 17040-CD400 for Coupe
Nissan Brake Pad Part Number:
VQ35 FRONT: D1060- AM80B REAR: 44060-AM485
VQ25 FRONT: 41060-AL590 REAR: 44060-AL586
I run Motul 4100 Turbolight in mine, I have done nearly 18,000 klm.
Quick run down is,
Air filter A360
Nigel,
Do you know if they are the same brake pad, parts #'s for non Brembo 2005 Coupe?
Cheers
Bobby
Nigel,
Cheers
Bobby
As far as I know they are the same,
If i call nissan up with that oil filter part number will they know what it is? Or would it be under a different part number for nissan but exactly the same?
I have never run into problems, the JDM VIN is on their FAST system anyway so any part can be ordered.
  • 2 years later...
Hi everyone,
My V35 250GT just done over 40k km and needed a oil change!
Whats the part number for the oil filter and can i use the 350GT or 300GT oil filter?
Any help will be appreciated
  • 1 year later...
  • 1 month later...
When I bought my V35 350GT, it had a Z547 oil filter installed, I looked up the specs and these have the same thread and seal as the Z445, but they are a larger filter (longer)
Not sure if there is any benefit, unless you are extending your oil change intervals and allowing the standard filter to get clogged, then there probably isn't any benefit with a larger filter, but just thought I would mention it.
is it the right no?
21200-31u03==> Thermostat & housing
13050-31u00==> its gasket
Yes, it is correct.
Nothing unique with the V35's VQ35de... exactly the same as a 350z.
VQ25dd, VQ25det, VQ35de all use the same thermostat, oil pump, oil filter, air filter, fuel filter etc.
Yes, it is correct.
Today i went to Nissan here in Brissy and ask for a set of thermostat for my 350GT, he said 21200-4W01B should be the right one...that's weird..if all VQs are using the same Thermostat why 350GT is different from others.....
Check here http://www.infinitipartsusa.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=55 ==>21200-31U03, G25/M37/G37 all using the same part no.
However, http://www.infinitipartsusa.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=55==> 21200-4W01B , G35 ONLY???
Which is right, mates?
Check here http://www.infinitip...ogOEM&siteid=55 ==>21200-31U03, G25/M37/G37 all using the same part no.
However, http://www.infinitip...ogOEM&siteid=55==> 21200-4W01B , G35 ONLY???
Instead of getting a replacement Nissan thermostat, why not log into RHDJapan.com and buy a Nismo thermostat.
The work perfectly and you will have no issue with this confusion you seem to have.
If you need a Nissan one TODAY, then give Nissan your VIN and they will use that to look up the correct part number.
Also, sometimes Nissan parts are changed, whether minimally or completely redesigned, thus the older part number is superseded.
This is the reason there may be more than one part number for a particular part.
Having said that, I can assure you that the Nismo thermostat for VQ35de will work in your car. .. as it does in my mates V35 (VQ35de + T), another friends J31 Maxima (VQ35de) and a number of Stagea's (VQ25det). It will also work in the Stagea that I have coming from Japan (VQ35de).
Dunno what else to tell ya, we have been playing around with these cars for around 5 years but hey... what would we know, we don't own a "350GT"
 Share
