Umm - I'd rather not have to be so careful with it if I can fix it. I was hoping to get as close to OEM driving behaviour with quite decent power.. I haven't heard of many others with this problem so Im thinking it may be in the turbo.
I just put on an Rb20 10 psi wastegate actuator, once I get the new injectors in and fix up whatever im going to do with the intake I will take it to the tuner and see what they can do..If still an issue will take the turbo off and get a different wheel put on it to reduce this effect.
Mine is an earlier GCG so I dont know if they have fixed them afterwards.
  • Replies 62
Posted Images
I remeber the really early 500hp rated GCG's had issues with surge but that was when your getting stuck in to it. I don't remember any issues related to when u jump off the throttle.
So your bov hasn't been modded so to speak? that little bleed hole in it blocked off?
Any chance of a vid of you driving it and it doing the jerk when you get off the throttle so we can see just how bad it is?
Could do I guess..good idea..but the size of the exhaust wheel will still be the same..
Would have to get the R34 exhaust housing bored out to same size as my one though..
Might be able to get a little video cubes. No mods to BOV, stock one etc..
Thanks guys
Edited by benl1981
Off topic>
I never had an issue with my old gcg high flow surging, and i had the stage 2 one which was supposed to be bad. Admittedly it was only on the rb25 for 6 months or so before it cracked the exhaust manifold (modified trust high mount) and the HKS kit went on.
Back when the high flow was on the rb20 and i had to flog it to keep it on boost, i found that by blocking the hole on the stock bov it caused the car to surge on partial lift off, which is basically mimicing the behavior of a tight aftermarket bov or no bov. It was still fine on acceleration
On topic>
I know my current surge issue is almost entirely due to the .63 exhaust housing on the t300s combined with the t04s wheel which pumps more air at low shaft speed than an equivalent GT spec wheel. I'm not interested in changing anything on my car to work around it as it only happens at partial throttle highish revs as mentioned earlier (basically what i would describe as the no mans land between having a go and cruising). Simple work around is either get off the gas and get back on it, or give it more gas, as it's due to the compressor trying to push more air past the butterfly than it can flow. In your case the stock bov is more than likely masking it somewhat as it has the bypass. If you blocked it off completely it would be worse.
The r34 rear housing mentioned by manwhore will fix the issue (well i'm 99% certain) whether it then moves the point of surge further up the rev range with a different amount of throttle is anyones guess, particularly with a high flow.
Too many dots cubes.....
Edited by BHDave
It's quite likely. It also assumes you have an r33 spec rear housing (likely). I think it may be worth while talking to GCG about it as they have the experience. But more than likely they will come up with a similar solution, namely, reduce the turbos ability to push air at moderate load with low throttle openings. They are also likely to be able to tell you whether that will have an effect somewhere else (other than the obvious raised boost threshold)
Yeah I've spoken to them quite a bit and shown them pics of my turbo before I installed it. They can't see anything wrong with the specs.
I know it has an R33 exhaust housing..so yeah maybe the R34 one would reduce this effect. Might be the easiest solution - just machining off the cg30 housing as opposed to changing wheels..
I found a vacuum hose that wasn't connected - the one just after the AFM off the rubber intake pipe that connects to the solenoid. My solenoid isnt used ( always closed) but I usually connect it up to close the system. This hose was just dangling there..
Will check tomorrow to see if it makes a difference..probably not.
I really am a little concerned you may be barking up the wrong tree.
Another that has experienced the same issue but more severe; a large longer inlet pipe sorted the issue.
http://www.skylinesaustralia.com/forums/in...5074&st=40#
Have a good look at what the problem is before you go out and waste money making your turbo more laggy for no good reason....
Part throttle constant acceleration, boost starts to build and then begins surging. Turbo match related and quite common with big turbo's. GT35r's on rb30 sohc's see a little compressor surge under this circumstance.
Surge/jerk as you back off the throttle after accelerating IS afm reversion. No doubt about it.
HKS EIDS FTW. Nengun - $137 delivered.
The HKS EIDS has been developed to buffer dramatic airflow meter signal fluctuations. By buffering these fluctuations the EIDS prevents engine stalling or stumbling associated with sudden imbalances in air/fuel ratio of airflow meter-equipped vehicles that utilize atmosphere venting blow-off valves.
Sounds like classic compressor surge to Me. I've seen a couple of guys mount the AFM between the I/C and the throttle body - that would prevent any air flowing backwards through the AFM, but it won't stop the surging. I'd suggest looking into a (second) pre-I/C Blow-off valve (plumb-back of course!) that'll bleed-off pressure with only a small pressure differential between intake manifold & compressor exit. That'll vent the pressure peaks & smooth/reduce the surge pulsing.
Short of getting some precision compressor/housing machining done to move the surge line, backing off the boost at low rpm is the only real way to eliminate it. My Turbo is prone to surge at 0.5bar at 2,500rpm, 0.65bar @3k, 0.8bar @3.5k, etc. etc. It's called a stall/surge line. get used to it. :thumbsup:
Hardman,
I've highlighted the areas of importance.
One of the things I notice on the map trace if you hit it in 2nd (or any gear >1st) and then back off - i.e. rev to about 4 or 5k and then back off the fot doesn't go straight back to the top - there is a slight delay. THen when it hits the top It shoots back down the vertical axis for a second or so even with the throttle closed.
Thanks
What ben is saying is your crusing along on boost, lets say up a hill. You then back off the throttle the boost guage reads neg vac, the bov releases, the pfc's map trace bounces to the top then quickly back down a little (this is when the car jerks forward) then back up to the top.
Bens surge (well it feels like a surge/jerk) isn't occuring when boosting; its occuring when you take your foot off the accelerator as a result the BOV does its recirc thing.
So in short.. No Ben isn't experiencing the traditional surge you have suggested. That being when accelerating and making boost.
I'll say it again; depending on driving conditions I am easily able to make a stock turbo'd Skyline do this little surge/jerk when jumping off the throttle.
Yeah, that part of it (what the hell is "fot" ?) I wasn't real sure about - I'm guessing that's just lagging air in the intake system getting pushed out backwards through the AFM ?
I've found my Hi-Flow turbo will start surging slightly (without stalling the compressor) at low-rpm and middling load, on small throttle openings. Plant the foot and it cleans up the airflow, cuts the surge.
I think there's TWO things going on here - compressor surge, and BOV recirc-blowback.
You missed this bit cubes;
Also going up a hill in 4th gear hovering around 0-3psi you can see the dot flutcuating between about 3 or 4 load points in the vertical axis with a steady throttle opening.
Thanks
There are 2 issues, the throttle back off reversion isn't the important one as (unless it's causing the car to stall) it really has no effect on drivability, which is why i've generally addressed my responses to the on throttle surge issue as quoted.
Yeah sorry Cubes. I do have an issue when holding a constant load also... i.e. around 0-3psi.
So a non-BB housing is not interchangeable to the rb25 turbo?..Does the VG30 non-bb turbo still have a 45V1 on the compressor housing..i.e. how can you tell?
Hardman69 - what sort of highflow do you have??
I would like to rectify this. I don't think the boost control will fully get rid of it..since the problem is very close to atmospheric pressure or at 2psi etc. The wastegate should be fully shut around this area.
Like hardman said - fully opening the throttle clears it up.
E.g hold a steady light throttle up a hill (promoting around 0-5 psi) and you will get reversion and a jerk. If you do the same thing but fully open the throttle from the start you won't get it.
When you change housings you still have to get new seals don't you. GCG reckoned that to put on a new wheel they had to put new seals in. ..they said anytime they dismatle a turbo..!
I would have thought the cartridge would be sealed though.
I wonder if the R34/vg30 housing would fix this issue.
Edited by benl1981
If you are holding a steady throttle, boost builds and while holding throttle it begins surging then yes that is compressor surge.
So what issue is difficult to live with?
The holding a steady throttle, boost builds and then starts surging 'while' holding that same throttle opening
OR
Accelerating on boost, reduce acceleration, BOV recirculates and you get the jerk and load points diving.
If its the later; don't mess with making the car laggier the only solution that will fix that issue is playing with inlet pipe dia and length, atmo bov, hks EIDS, or atmo bov + hks eids.
You need the BB core VG30DET turbo. :(
http://www.mygen.com/users/dbruce/myz31/images/P7210029.JPG
You can see the different VLT Style dump design. The wastegate is integrated into the dump pipe.
I 'think' rad33 from SA had a couple of VG30DET BB turbo's that were stuffed and wanting to get rid of.
Well some one did.. :)
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
