Cubes..
"The holding a steady throttle, boost builds and then starts surging 'while' holding that same throttle opening"
That is the problem that I find difficult to live with. Motorways etc when doing 100km/h in 4th or 5th. This is definately a problem when holding a steady throttle and boost just coming on whilst maintaining same throttle input..
ANd when I say flicking between load cells...its more like 3 or 4 cells.
The AFM voltage I can see flicking between 2200 mv and 2700mv, you can feel a slight roughness but this oscillation is usually followed up by a large jerk and you can see the AFM voltage jump straight down the vertical when this occurs.
  • Replies 62
Posted Images
Its all good. I did skim read a touch and for one reason or another didn't see the 3-4load point drop but read it as flicked between load point 3-4. :)
Yes a larger turbine housing will sort the surge.
Improve the motors ability to breathe will also; You have cams and cam gears yet?
A turbine housing might set you back 50-100 + 300 for machining. Might be better off put towards a set of cams or reground rb26 cams? BUT its still not certian the surge will be sorted.
Reground rb26 cams are a shade over $200 for 2 sticks. You net around 8.5mm lift and ~252-254duration. So a nice mild increase that won't completely kill your low end.
Thanks Cubes. No I don't have cam gears or others. I am in negotiation with GCG so I may be able to sort something out with them because the turbo was sold as a standard Rb25 so should suit the car the way it is.
New cams are a big deal..take timing belt off, rocker cover etc. Not really up for that.
Your after the OP6 turbine housing.
I can't see by that pic if it is an OP6 or not.
The compressor backing plate actually looks the same as an early (series 1) RB20DET BB turbo I've seen.
Its definitely not the run of the mill Leopard/Cima Vg30DET turbo; it 'could' be a really really early turbo from one of those. Not sure.
The only VG30DET turbo I've seen is that from the Z31 which is journal bearing and then that of the later leopard/cima. The R34 GTT RB25DET Turbo also runs the same OP6 turbine housing that the VG30DET turbo does.
Can't be sure exactly what that turbo is without seeing more pics.
The OP6 is stamped on the outside of the turbine housing near the core.
So thats a journal bearing turbo?
Would be interesting to know what car that is off as they are an extremely extremely rare turbo if thats the case.
The Z31 VG30DET's as I said above run a VLT style turbo where as the Leopard/Cima VG30DET runs a the BB OP6 Turbo with 45v1/2/3/4 on the comp cover. It 'could' be the really early 1980-1986 Leopards; I'd assume they would have run around with the journal bearing turbo's. But whats interesting is why would they not have used the same old VLT/Z31 turbo.
http://cgi.ebay.com/ebaymotors/VG30DET-TWI...1QQcmdZViewItem
Thats a Vg30DET BB turbo with its OP6 Turbine housing.
Ha HAA ! I am sworn to secrecy on my Hi-Flow, suffice to say it'll do about 270rwkw, and has a watercooled plain-bearing core. It's not excessively laggy with the AVC-R tweaked-up correctly - certainly does the job for me, anyway!
Maybe You should investigate how changing the compressor housing slightly would affect surge? This seems to be at the heart of the problem, after all. Half a mil' here, a few thou' there.. . . might make all the difference.
Cubes, have all the ones you seen had OP6 in that location. This one has Y24B..
might not be right.
Hardman - sounds like you got a good turbo there. The secret recipe :) Yeah I think the compressor is where it's at but the exhaust housing may be the cheapest to change..
All of the larger turbine nissan turbo's I've seen have the OP6 on them.
You can't get any more pics? Get one of directly looking at the comp wheel also showing the compressor cover and one of the turbine housing in a similiar position. Then we can see both wheels and know or at least have a better idea of what it is.
Its definitely not a run of the mill VG30DET turbo; I suspect its something old. I suspect that due to the comp covers backing plate. Either that or its been highflowed.
If you have the turbo take some measurements of the turbine scroll at points that are easy to describe and I will compare them with the one I pulled off mine a little while back.
From memory the cross section width near the wastegate flap is ~5mm wider with the OP6 housing compared to that of the rb20/rb25 housings.
Anybody know if this looks like BB turbo? Do the non BB turbos still have exhaust housings that are useable?
thats a non ball bearing turbo, u can tell by the ribbing on the back of the front housing. To me it looks like a t3 off a VL Turbo!
Edited by mr_rbman
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
