my s15 rb30 keeps having issues when braking at high speed with oil pressure. it drops right off after a few laps with heavy braking. i tried doing a simple mod with a brake bafffle in front of pickup but cant be bothered p1ssing around every month re modifing it till it wourks 100%.. i still havnt used slicks which would really upset it..
ive decided to do a simple dry sump setup with a few additions..
i was thinking of blanking off oil pump with a 10mm plate with oil seal, (std seal with machined crank to sut it 30mm further back... this would give a perfect place to run my 5" 60-2 trigger wheel.behind cambelt. as i wont have much room on crank pully as of ps alt and oil pump.
and making a simple but stong and thick 6-10mm scavange /sump tray it would be spaced perfecly to clear cradle..
and machining flat 14mm seats to cradle with 5mm spacers, so oil can pass under. and tapping some 8-10mmcap bolt holes in cradle to strengthent the bottom end they would be attached to the thick sump plate and into cradle this will streghtent the bottom end from twist and serve as a scavange sump. and would be cheaper than a custom cradle.
i want to run higher hp 700+ one day and have heard the block can get weak at this level. i will also lower engine.. and maybe look at mid mounting engine some day as would have virtually a flat bottom
does this sound doable? how many holes should i drill and where are the safe places in cradle to drill and tap? gtrs have a good 30 6mm holes std whoch dont strenghten so a few "helpfull" holes woulnd hurt would it?
i will use a simple 3 stage pump with twin sump scav.. prob just 50mm from front and 50mm from rear of sump? is that the normal?
any suggestions. is drilling into the cradle worth trying or could i go backwards in strengh?
allows you to run a proper scraper, and a sump designed to catch the oil in the right places to get sucked out with room for inline filters and fittings. Dont know about gtr sumps, but std gtst ones arent too friendly in regards to those things. Plus a new ally one looks the piece ;)
im replacing modified 2wd one.. i know dry is what i want its just hiw and if i make it attached to cradle is what im consorned about.. and is making a flat bottom (but slightly sloping to exh side) is practical, do i scavange from exhaust side? the natural 5 deg engine lean would help it. and all head and turbo returns are on that side, i would make simple scraper attached to cradle.. therfore very little oil would return on intake side of sump
Edited by GDZ1LA
You definately dont scrap from the exhaust side, that would be a fatal mistake for your engine.... YOur engine spins clockwise spitting oil off the crank into the right side of the sump not the left (exhaust) you would have bigger probs than you have now.
Not trying to be rude or having a go but the way you have explained things sounds like you need alot more knowledge before attempting a dry sump setup, I can appreciate thats why you are here asking questions but to do a proper dry sump setup requires a fair bit of understandin especially relating to RB's. There are many things you can do to make it work better than you have proposed like secondar oil feed to ensure even dispersion of oil pressure to all 6 main bearings, and also ensure even scavenging. As mentioned there is scraper design, quite cruicial, also vacuum can be achieved. I would recommend highly a 4 stage as to scavenge out of the head. THe tank design and placement are important, you cant beat a moroso or peterson tank as they de-airate the oil as well. Crank case ventilation needs to be more than adequate especially if running vacuum. I dont recommend your idea of running the belt behind the balancer either as the pump will sit too rear wards and foul on the engine mounts.
A good 10 litre sump and proper trap doors will fix you problems I can assure you, maybe an option as the dry sump route is definately an involved one to do correctly.
Edited by Fitzpatrick Speed Works
hyperdrive run a dry sump in there cefiro so they would probably be good people to contact
Just to let you know its not Hyperdrives car its Borneo and all work was done by Lumpy (Glenn Campbell) in our workshop in Wanagara
bloudy cefiros and their stupid lower crossmember. So much more room under there for a nice sump pan.
The Cross member in the ceffy is an R33 crossmember the dry sump pan is pretty much flat across the bottom of the block except for 3 suction pick ups. The Tank and system and sump hold about 15 litres of oil.
really...i didnt know it was changed to an r33 crossmember, glenn never mentioned that to me last time we spoke. But i know about the sump. There are many photos on my comp of it. Only thing about glenn's setup that i didnt like too much was his lazy attempt at a scraper, not being rude its more in jest but a proper plate with louvered wings facing towards to the exhaust side would have been better to break the vaccum, think i mentioned it to him at somestage. Doesnt matter anyway, but he did a good job setting it all up, and its a nice sump and the car is nice also...i could sure steal that motec dash he put in along with that strain gauge he was talking about for the flat shift......*drools*
Edited by r33_racer
I'd run a scavenge section for the head, too, myself, and get around the lack of drain back the RB engines suffer from.
Let us know how you get on, I too am considering dry sumping a 2WD car with RB26 engine. I came to the same conclusion re blanking the front of the engine off, although I believe you could use the tomei pump as the pressure side, and belt drive just the scavenge sections. I think I'd go for remote pressure and scavenge sections though at the end of the day, so pump overhaul isn't a sump off jobbie.
I will go with what Michael and Fitz have said. Dry sumping is good, but it COSTS and requires some knowledge and considerable fabrication skills. I have been involved in several dry sump set ups for GTR's over the years, due to the design of the 4wd sump, they really need it. But not so much so in a 2wd application. For example, in my own R32GTST I run a High Energy 8 litre wet sump on the RB31DET and I have never had a problem with oil surge.
I would like to comment on this;
That doesn't sound like oil surge to me, more like you haven't sufficiently limited the amount of oil getting to the cylinder head and/or improved the oil return to the sump. On the straights, the high rpm is pumping too much oil upwards and it isn't returning to the sump fast enough, this lack of oil in the sump manifests itself under brakes. That is where I would start looking, limit the flow and improve the return.
:D cheers :(
:yes: cheers :P
i have a 1.3 mm restrictor on a std gtr pump with collar.. with std oil returns
ill try add a larger sump with gate for braking.. as soon as i accel it returns stright to normal.
next time i rebuild ill overside the 6 oil returns to say 9mm.. i dont want a external return if i can help it
you really should have the external return. Why would you want a dry sump setup, yet not one external return. You do realise with the setup there will be quite a few lines running everywhere?
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
