R32gtr Wheels-awesome Condition, Hks Pods
Hey Max32, what are your results on this issue? Did you ever fixed it? I am in the exactly same situation like you. Waterhose was cracked and i removed the Plenum, throttle valves. Air Chamber and replaced all waterhoses and vacuumhoses. After reinstall and putting all in the exact same placed back together, i cant boost over 0.7 bar. Besides that, the car is just fine - no issues. Have no boostcontroller and always removed the restrictor for gaining 1.0 Bar with Steel Turbos. But now its like and it feels like the restrictor is back. I have no clue. All was fine before. Also tried to bypass the solenoid (thought it was blocking or something) but there is no change. regards
also did the all Japan day at shepparton a few weeks prior more strangers cars!
What you can try is to disconnect the hose with a clamp( or bypass ist with a short tube) . Its under the manifold on the left side . so you can check if it has any effect on the cold start
