I filled up at Bp today, I only ever use the Bp Ultimate expensive stuff, and literally a couple of hundred metres down the road my car isnt exactly misfiring or anything but is running exactly how it did when I was forced to put crap fuel in it once. This has annoyed me to no end. Anyone else had a similar problem. Did you do anything about it?
I am going down there tomorrow to have words with them. Highland Park Bp, as my car has a noticeble lack of power.
Only mods are apexi power panel filter (100kms old) and 3instainless exhaust front pipe back.
So yeah anyone else done anything about it?
Regards,
Jordon
https://www.sau.com.au/forums/topic/173303-bad-fuel/
go to BP and complain
tell them that the fuel is shot get a refund..
i got bad fuel from Caltex... once..
never again..
was in my old GTR.. after that.. it fouled my plugs.. wouldnt rev over 6k.. fixed it with new platniums .75mm and optimax... :P and then it revs to 9k.. lol crazy jap tuned car.. been using optimax for years now.. all good.
https://www.sau.com.au/forums/topic/173303-bad-fuel/#findComment-3186429
How long has it been since you did the fuel filter change? How empty was it when you filled it up? how do you exactly know the fuel is at fault? Have you tested the fuel? Only a fuel test itself will tell you its the fuel, have fun getting that, If you think its the fuel completely drain the tank shyphon it into a jerry can or a couple of and replace it with new stuff. Could be anything not just the fuel thats causing it to run crap, ie: injectors, fuel pump, Fuel filter, spark plugs etc?. Does the car ping/knock?
Have fun ;)
A
https://www.sau.com.au/forums/topic/173303-bad-fuel/#findComment-3186529
Yes, I've had a similar problem only my bad fuel blew my engine on the track. Leaned out and melted 2 pistons which ended up putting the bearings through the turbos. Made a complaint to the fuel company. They have a third party company who look after all complaints. There had been an issue at the time whereby plugs were being destroyed by certain batches of fuel containing a contaminant. With my case they had the fuel tested and came back with "all levels within tolerances". Either way I ended up with a $10k bill out of it.
Worth a complaint - don't know how far you will get though.
https://www.sau.com.au/forums/topic/173303-bad-fuel/#findComment-3186544
Have fun :(
A
^^^^^^^^^^^Agree, same what he said^^^^^^^^^^^
I found my car didnt like the BP ultimate, so i dont get it. Go the V power.
Edited by subzeroR33
https://www.sau.com.au/forums/topic/173303-bad-fuel/#findComment-3187571
ive only ever use bp ultimate in all my cars... my skyline especially- i used v power once car ran crap till i used all the fuel up. filled her up with ultimate again and never had any issues- just had car tuned by matt at P.I.T.S bout week ago and had no problems with using that fuel, all my other mates use it too no dramas- maybe that particular servo got a bad batch in and you got the crap fuel that day? but yeah i have no issuses with it. :(
https://www.sau.com.au/forums/topic/173303-bad-fuel/#findComment-3187768
Have fun :worship:
A
Thanks mate, there is no pinging or knocking and the car still runs fine its just feels as if it has low grade 90ron fuel in it. Only time will tell as I draining the fuel and trying the Bp at Ashmore. Hopefully this solves the problem.
Thanks for everyones opinion also!!
Rgeards,
Jordon
https://www.sau.com.au/forums/topic/173303-bad-fuel/#findComment-3188422
Well I drained my tank to nearly empty went to shell at surfers and got some of the V-power racing and bobs ya uncle she is rocking again, and when I say rocking i mean rocking...car is noticeably running better!
Thanks for all your replies!
Regards,
Jordon
https://www.sau.com.au/forums/topic/173303-bad-fuel/#findComment-3189732
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
