Hey guys. I have a hks mushroom pod and the filter foam need replacing desperately. Is it worth paying $50 for more foam or I can get apexi power intake pod for $85 new. I know the apexi is the dry type filter but ive heard nothing but good things about the hks pods. Whats best??
https://www.sau.com.au/forums/topic/173306-which-pod-filter/
i use a k&n pod filter. no dramas so far. fantastic local stuff :P
get the cleaner kit for it and do it every 10,000k's
Yeah ive had k n N filters before too, they are good. Just thinking maybe the dry type shit now that everyone goes on about the oil killing afm's??
K&N Pod. They don't foul your afm with oil either. They only do if you get over enthusiastic when your re-oiling. Even then if you do over oil just spray electrical contact cleaner over the afm element after you've taken the car for a drive. (allows the larger portions of oil to be ingested, leaving the rest in the filter.)
i had a KN now a HKS mushy...
KN louder then HKS
HKS dry KN oiled
HKS fits into smaller places where KN cant (eg my engine bay)
KN much cheaper (can get them for under $50 at autobarn sales)
If i had to pick another besides these two, wouldnt mind checking out the Blitz pod...APEXI no way, some say its good some say its absolute crap...wouldnt want to spend $200 on something that MIGHT be good.
But yeh i cant decide between HKS or KN
Ive got an HKS mushroom on my car.... give it a clean every few months... sounds good, looks good, lots of flow...
borrowed an Apexi Power intake one and put it on the car.... it was so farken quiet that it felt like i was almost driving a non turbo! plus the car didnt feel as quick!
hks one back on the next day!
The stock air box with K&N panel filter sounds so much more classy and refined. You can also hear the turbo spool rather than the awful loud sucking noises you get with a pod
my thoughts exatly. nothing sweeter than the spool. even though im on a stock turbo
Didnt feel as quick cause you couldnt hear the loud sound. from my experience the apexi is quite loud. Personally stock box with hi flow filter is good. no heatsoak and car sounds good enough. didnt by a turbo because of the sound it makes.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
