GMan Posted June 18, 2007 Share Posted June 18, 2007 An issue which i have only recently noticed is that my power windows on my r34 gt-t is going up and down really slowly. i have compared this to many other r34 gt-t's which my friends own. anyone know how to overcome this problem?? Link to comment https://www.sau.com.au/forums/topic/173319-power-windows/ Share on other sites More sharing options...
someonestolecc Posted June 18, 2007 Share Posted June 18, 2007 Try silicone lube spray on the window rubbers. I usually spray the window and let it go up and down a few times, then wipe it ALL off. (you're only really trying to get it into the rubber). This works assuming your electrics are good enough to power it all in the first place .. gl Link to comment https://www.sau.com.au/forums/topic/173319-power-windows/#findComment-3186453 Share on other sites More sharing options...
GTAAAH Posted June 19, 2007 Share Posted June 19, 2007 Do that then check your battery, i know of a r32 and a silvia who had the same problem, and when the battery's eventually needed replacing the windows went up like twice as quick Link to comment https://www.sau.com.au/forums/topic/173319-power-windows/#findComment-3186768 Share on other sites More sharing options...
32line Posted June 19, 2007 Share Posted June 19, 2007 yep, my r32 had the same problem. i opened up the switch and cleaned the terminals...fixed:) Link to comment https://www.sau.com.au/forums/topic/173319-power-windows/#findComment-3186914 Share on other sites More sharing options...
Rabid Posted June 19, 2007 Share Posted June 19, 2007 If your running a system, it might be drawing to much power from your battery/alternator, and that could affect anything else that needs to run off those as well. Link to comment https://www.sau.com.au/forums/topic/173319-power-windows/#findComment-3187090 Share on other sites More sharing options...
LBR33 Posted June 19, 2007 Share Posted June 19, 2007 I had the same problem in my 33 it turned out to be a dying power window motor, all you can really do is replace it Link to comment https://www.sau.com.au/forums/topic/173319-power-windows/#findComment-3187250 Share on other sites More sharing options...
vhs2 Posted June 19, 2007 Share Posted June 19, 2007 my passenger side window is slow as...my car is a r34 gt.. while mine is goin up, other cars power windows can go up n down 2 times lol.. Link to comment https://www.sau.com.au/forums/topic/173319-power-windows/#findComment-3187873 Share on other sites More sharing options...
a20089 Posted June 19, 2007 Share Posted June 19, 2007 Also you can check the alignment of the window, if it is not pushing in the correct angle it can slow things down dramatically. To check, when closing the window, pull the window upwards and to the front, then try upwards and to the back. If it speeds up (more than you are pulling) it is likely the window has fallen out of alignment. Not a common problem on skylines but fords certainly have this problem. Link to comment https://www.sau.com.au/forums/topic/173319-power-windows/#findComment-3188271 Share on other sites More sharing options...
GMan Posted June 19, 2007 Author Share Posted June 19, 2007 ah ok thanks.. i am running a system which consists of tv, 2 amps, speakers...subs have been disconnected now also have installed is a power window lifter kit. when i lock the car and the windows go up themselves with alarm it is faster then pressing it myself. Link to comment https://www.sau.com.au/forums/topic/173319-power-windows/#findComment-3188344 Share on other sites More sharing options...
Spunky Munky Posted June 19, 2007 Share Posted June 19, 2007 get a high-capacity battery - especially if you got alot of gauges that lights up etc, sound systems etc... get a more powerful battery brother... Link to comment https://www.sau.com.au/forums/topic/173319-power-windows/#findComment-3188479 Share on other sites More sharing options...
