1995 R33 Gts-t M-type
108,000k's
Complied and Registered
White
Sunroof
Tinted Windows
HKS 3037S Turbo
HKS External Wastegate
HKS Stainless Steel Manifold
HKS Triple Plate Clutch
HKS 272' Cams
TRUST Plenumn
HKS 6x740cc Injectors
Huge Fuel Pump
Custom Fuel Rail
80mm throttle body
HKS F-CON V Fuel & Ignition ECU
Custom G/force 600x300x100mm Intercooler
HKS Airpod on custom 100mm piping with airflow meter removed
Unknown Internals although almost definately forged pistons and toughened rods.
Line Locker
TRUST Profec A Boost Controller
TRUST Turbo Timer
TECHTOM IIC460 Drag Launch Controller
TRUST 60mm electronic Boost & Exhaust Temp. Warning Guages
Autometer Sport Comp Monster Tacho & Shift Light
Apexi N1 80mm Exhaust
HKS Front Pipe (Turbo to Cat)
Custom Stainless Dump Pipe
Cusco Oil Catch Can
Unkown Brand approx.. 90% Locking LSD
Veilside Shift Knob
Recaro Recliner Seat with Sabelt Harness
Potenza Suspension
Nismo 400R front bar (needs repair)
Different Skirts, Rear Bar and Drag Style rear wing
17x8 and 17x9" White 5 Spoke Wheels
Falken GRB FK451 245/45/ZR17 and 265/40/ZR17 tyres (brand new)
Slotted Front Brake Rotors and Aftermarket Brake Pads
Newly Rebuilt Gearbox with brand new internals
Built up by G/force http://www.gf-eng.co.jp/
15563669
15562702
15564018
If you are seriously interested email me or pm me. POA. Lots more photos available upon request.
Email: [email protected]
https://www.sau.com.au/forums/topic/17335-heavily-modified-95-r33-gts-t-m-type/
Thanx Dragon
haven't had it tuned in australia yet.... waiting for croydon racing development 2 get tha software.... jim said he'd have it in a few weeks.
To give you a rough idea similiarly modified gts25t's i have seen putting out about 300rwkw at 1.2bar of boost. With a dyno tune i am sure this would match or pass that figure on 98 octane pump fuel.
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
