hey guys sorry im new at this n dont know where 2 begin.
i have a r33 skyline gtst. and since i have bought it i have had alot of problems.
1- i cant find a power window motor 4 the driver side door. any ideas will b appreiciated.
2- they say my vct or vct sensor isnt working right, any ideas what i can do about dat and how much im looking, at???
the car suprisingly ran 213.2 kw's@tw at 14.8 psi. so im keen on taking care of this baby! :worship:
thanx guys hope 2 hear from u all soon.
p.s btw any tips on anything i sould know would be appreciated thank you.
https://www.sau.com.au/forums/topic/173425-driver-side-power-window/
the car suprisingly ran 213.2 kw's@tw at 14.8 psi. so im keen on taking care of this baby! :blink:
hi, whereever you are best place to find a window motor or regulator is from a wrecker or someone wrecking there car off these forums. its a lot cheaper than ordering a new part from japan. if your in sydney, a good place to try is sss automotives in girraween. As to the vct, i cant help you much, havent had problems with that, best talk to a mechanic. Also uve got good power but 14.8 psi seems a bit high for a stock turbo to handle. it may last, or it might not, you take the risk. if it was me, id bring it down a tad to be on the safe side.
hey man i had a no worky or intermittent worky window as well
all it turned out to be was a lose solder joint in the amp behind the door trim...all i had to do was open the lil black box behind the trim and re-solder the joint and it works everytime now, cost nuthin at all
so i'm just sayin if u def no its motor gonsky then fine...but just keep a mind open and if ur feelin adventurous then think about this re-soldering
ps, my window wss making the click sound as if to try and start to go down...but then the electrical signal wasn't making it all the way (loose joint). so if ya got the click happening then this could be it
common thing in skylines
  • 3 weeks later...
yeah i know wat u mean wid the not boosting but im gona go for a turbo injectors and ecu upgrade pretty soon. so looking forward 2 that.
the trick with the soldering ill give that a go cvoz its making a click sound but doesnt move. or goes down wont come up. or vica versa!
sss in giraween and virginia in qld. do u mind if i ask 4 the contact details???
thanx pplz!
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
