  • Replies 53
Guest INASNT
Originally posted by Soulja
ahahahaha :bahaha: :bahaha: :bahaha: :bahaha:
ok where should i start on this one;
ok i got it my vette is a 1988 model which can hold over 500rwhp on it rear (dana 44), people in the states have got up to 650 if im not wrong. now lets see the skyline we are talking about is a r_33 which is mid to late 90's and can hold around 500hp also how is that stronger than my vette? or other american cars?
I would like to see this guy race me in feb next yr (04), some how i dont think his 400 or 500hp skyline will come close my 500rwhp vette.
:) learn about car and then can i reply to this. if a rear-end in a 80's america car is as good or better than rear-end in a 90's skyline how then is the american car the pos? hmmm
after that who cars, its still an american piece of junk with shit quality controlled parts! :D
Latest HPI magazine tested the new C5 vette vs a R33 GTR and even tho the $95,000 C5 beat the $45,000 R33 by around 0.3 secs in a straight line when the corners came around say by by to the C5 in the rear vision mirror. And the ending statement was quite accurate it read something like this, 'While the GTR has been designed by engineers the Vette seems to have had more input into its design by the marketing department than any engineer, it looks the goods but cant delivery them'!!
Now back on topic.
Soulja, gearbox? Shift kit? What have they got to do with anything? I will give you the benefit of the doubt re: the brakes and assume you are talking about pads only. But you forgot to mention tyres.
Lepperfish, you shouldn't have to upgrade your fuel system until you get over 220rwkw or so. So if you get a 500hp turbo and can't afford the fuel system upgrade, just run it on lower boost until you can. EBC does wonders in this regard.
Originally posted by T0nyGTSt
Fuel rails can get expensive. Really I don't see the point of a fuel rail if it makes the whole thing more than the Sard/Nismo side feeds.
T.
Umm it really cost him SFA cause he made it from efi hose...Just t'd off the hose for ever injector etc etc, cost him SFA in the end...maybe $60 for the whole rail including fittings, and he used the stock FPR so thats not an issue..... Twas easy as to fit and works well!!
Soulja im afraid to say that i have never heard of anyone blowing up diffs in skylines..They might loose they LSD effect but i've never seen anyone blow one up..or 1/2 shafts for that matter either...Or gearbox's.... They are strong buggers, well over engineered :D
Yeah im wanting to do the upgrade in one hit, so I can see maximum results, what do you think if this turbo ? New 2835 pro s with t 3 flange, will give 300rwkw at around 1.3 bar and costs $3100 new... How much boost on the standard rb25 engine ?
Guest INASNT
Get the engine Professional Tune (by a tuning company) this will result in the engine being able to hold more hp (not to mention u will get extra hp and torque)
thats a gibbon!
do u seriously live in Australia?? professional tuning company?? hehe havent heard it said like that before!
Guest robertr
Ask GCG for their best price on a brand new Garrett GT40R with .82 AR rear and fit a external wastegate. Ask Brett there about his GT40R .82 with internal wastegate that will bolt straight in. He said they are coming in in around 2 weeks. Then email me your price and I'll see if I can beat that for you.
[email protected]
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
