R33: (gts-t) Series 1 And 2 Differences
PranK
  • 3 weeks later...
my S1 has a big wing i think its a GTR wing i am like wtf if going on Also do all S1 have air bags cause i don't think mine does
is there a way of Telling if i have LSD on silvia u pull back seat out and there a sticker
hey the wing is a gtr style wing
air bag was an option until 1995, in 1995 drivers airbag became standard, and series 2 skylines (very late 1995-onwards) all have dual airbags standard
all gts-ts have LSDs standard (i told u this in another thread!)
What about sunroofs? where they available in all of them? s1 and s2?? anyone got a series 2 with sunroof?
i cant seem to find a s2 with a sunroof... what would you choice... the upgraded s2... or the s1... with SUNROOF!! :jump:
Sunroofs were an option, at least with S1. Mine was optioned :headspin:
And thinking of I don't think I have seen any S2's with them, at least not as from the factory.......................
']What about sunroofs? where they available in all of them? s1 and s2?? anyone got a series 2 with sunroof?
sunroof was most definetly offered in series two from the factory i have seen a few of them.
  • 1 month later...
Differences also include the 40th annv stitching in the seats lol if you've got one..
nismo front bar, rear sway bar in boot, gtr rear wing, sunroof, hicas..
i'm sure these cross into SI and SII - depends on what the original owner got factory..
also what about HICAS - do SI have hicas?
Another trivial but important tip for buyers of secondhand parts.
I tried a series 1 aerial on my series 2 and it's different, the aerial plug is different, the S1 tube is fatter, thusly the screw on crome bit too and the angle of the grommets is heaps less. I mangled the S2 for the arial plug and fitted it, but the angle grommets FMU and it didnt two stage anymore. (notice that the plug surround on the S2 is yellow) With the slimmer tube they made the black outer grommet go through the panel to eliminate earthing / potential rust spot?
so can anyone list the HARD AND FAST FACTS that a buyer can use to tell between a series 1, 2 and 1.5 if they are a different model between 1 and 2?
do ALL R33 GTS-T's come with an LSD, or is it an option?
is there anyway to tell the model of an R33 by any identification numbers etc?
The definative way to check the model is using the FAST software from this thread http://www.skylinesaustralia.com/forums/in...++nissan++check
But simply, the Series 1 v Series 2 differences are in this thread, a series 1.5 looks like series 1 but has the series 2 motor (ie no ignitor pack)
    • Hi fellow SAU members, I want to put coupe tail lights on my R32 sedan. I have been told it was as easy as changing the boot lid and the tail lights and possibly the rear bar. I have since found out that this is incorrect after buying the lights and boot. The coupe boot dosnt allow the boot to oprn on a sedan and the tail lights won't fit either. Has anyone done this or seen it done and could help me out with some guidance or instructions to get it done.
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
