plus optional GTR rear wing.. plus the usual options.. dual airbags.. hicas.. haven't seen one with an a-lsd.. also there are others including Momo steering wheel.. different gear knob.. "sports exhaust"..
I should print them all out of Nissan fast..
mines got the GTR wing, the momo wheel, and a factory nismo muffler, but still the stock exhaust (not 3" cat back etc).....
the momo wheel is porn by the way, i love it.
does the series 1 have the ciggy lighter light up and ashtray light up
when normal lights are on? i havent noticed it on any other series 1 33's. do all series 2's have this?
Series 1 ciggy lighter light up when normal lights are on.
Series 1 doesnt have ashtray light.
my is 95' r33,
soo it should be same as series 1.
speaking of rear windscreen washers (which im certain they ALL had from factory) so yours must have been removed (perhaps when the rear window was smashed and replaced..)
i cant get my rear washer jet to work? ive been told it feeds from the same bottle as the front, so i topped that up, front works fine, but rears doesnt spray...i can hear the motor trying to spray water, but not a drop...anyone able to help me?
Yeah same here Dezz. I could hear the motor goin but no action.
Then i found a nice little puddle in the boot one day after doing that :
And after pulling the carpet down that hides the battery i found a small clear hose thats wasn't goin
anywhere.
But for the life of me i cant seem to find where its supposed to connect.
It apears to have never been there. The MDF on the rear shelf appears to be factory with no hole for where the wiper would come from. The wiper stalk also does not have the rear control on it. ????
It doesn't? The wiper control in mine is activated just like the driving lights except on the wiper stalk.
I have given up on trying to get it working. Not like i would use it that much anyway.
Hey there, got a link here, that shows you all the different models they came out in, just click on the year skyline you want, and shows you different models, might be of some help for some one.
http://english.auto.vl.ru/catalog/nissan/skyline/
let me know if it works ok.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
