Alsd were a option and expensive too.
Type M are turbo, NA's could be optioned with this and like all options it was up to the original buyer what your car has.
Options that I know of from factory (Nismo had others as well)
Sunroof
ABS
Alsd
Front lip (S2)
Rear Pods
Side skirts
Cruise control
Fog lights (S1)
Front bar (S1) dont know if S2 had front bar option aside from nismo
Steering wheel (S1)
Air Bags (S1)
Others?????
I thought the rear pods, skirts, and front lip were the M-Spec?
My 96 s2 has the M-Spec bits, but no sunroof or ABS (optional)
Some sites list 95 (1.5's) models as series 2, and also list ANY series two as M-Spec. I thought the whole bodykit on the series2 was the M-Spec option? It probably had stiffer suspension or something too?
FAST shows my car as being a "GTS25TM1"
Curious to know if other series2's don't have the "M1" bit at the end?
it hurts...THERE IS NO SUCH THING AS an M-SPEC R33!
do you call a GTR a TGR just because its kind of similar?
it is type-m. period.
there are no 1995 series 2's...only the made up "1.5" which have the series 2 motors
Sideskirts and pods were an option, and a pretty common one.
hehe! OK! Type M it is!
So FAST says I have a gts25tm1, which i'm assuming is Type-M I, not II... which has the following options:
"Front spoiler, Rear window wiper, Anti-lock braking system, Navigation system, Ultraviolet reducing glass, Tinted windows"
I have the front spoiler, but does that include the skirts and rear pods? It seems that if you have one, you have them all?
Got wiper and UV glass (I think)
  • 1 month later...
It apears to have never been there. The MDF on the rear shelf appears to be factory with no hole for where the wiper would come from. The wiper stalk also does not have the rear control on it. ????
I haven't got the rear window wiper as well as no control on the wiper stalk...it gives the car a much sleeker and cleaner appearance from side profile. Its a 97 as well.
How can you tell a type m from the normal model?
one of the easiest ways with the 33 is to pop the bonnet, look down the passengers side of the engine bay, and if there is a turbo, its a type m, if there isn't then it isn't a type m.
the 32s have bigger brakes, leather triming inside (gear boot, steering wheel, and handbrake cover)
Well aparently the turbos are different not only in the plastic compressor but it is a different designed compressor fan as well, which isn't really surprising just not mentioned.
OK, so how do we tell if its a s1, s1.5??? if some or all of the parts match or dont match what has already been said about these.
i have a s1 (im sure) but some of these guys with s2's have similar htings to my s1 , but my car aint a s2. etc..
need a vin check somehow. i know holden do it.(to some extent). anyone got any ideas?
Hi there,
I'm new to r33'S, I'm in the process of purchasing a 96 gtst.
A little off topic but Question:
"What's happened to the Cruise Control in these things? I read a spec sheet and it said that the it wasn't even an option in the S1-S2."
Is this correct? If so WTF?????? My run of the mill turbo '88 Z31 has cruise control std......................
I've noticed the bracket for the cruise control cable is there
but no cable etc.
Anyone have C.C on an R33 GTS?
[ http://www.skylinesaustralia.com/forums/in...ic=9479&hl= a link but no real answer]
Mike.
Edited by Mike5444
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
