just like to add here peeps (mainly for others WHEN you hit this problem ) i am rebuilding a 93 "S1" GTST. and came across the dreaded coolant filling the passanger carpet area..!! THE BLOODY HEATER CORE..!!
removing the "heater core" is fairly simple...and ordered another one.....(did not fit ..? )....then other one....(did not fit..? )
I HAVE since found out there ARE 2 SIZES in regard to the heater cores in a R33 SKYLINE..? I cannot tell you IF the "S2' runs the thicker (35MM thick unit ) ...over the/ my (25MM thick unit ! ) the core / size IS the same....just the thickness of the 2 units..?
and obviously they are NOT interchangeable..? it pays IF you have to buy another one :::: ask / tell the seller to check thickness of unit..?
in my case I needed the "thinner" 25mm core...most were 35mm thick..?
those that want to know ::::
S2 front bumper onto a S1 nose....do-able ! (note:: must have the same REO BAR ) ie::: S2 bumper onto a S1 car using S1 REO will NOT FIT !! as stated here....headlights WILL stick "forward" off the S2 bumper as will the grill. unless ALL S2.
(also if you have "fogs" in your S1 bar. and are fitting an S2 bar. make sure you have the small wiring loom off the S2 fogs..? you WILL have to change the "connector plugs" from S2...to....S1 so they work in your S1 CAR..! )
gauge cluster interchangeable..!!
dash cluster surround face interchangeable !! sharing IS caring....LOL...all the best....
  • 1 month later...
are the series 2 gtst rear seats the same as the gtr?
Same in what way? None of them have the same upholstery / stitching but after owning 3 x R33's myself (incl GTR's) I reckon they'd all be interchangeable.
not sure avout gtr seats (might have to measure up) but sedan Back seats r wider by about 2" and the mounting hooks are in different spots
  • 9 months later...
16 hours ago, Sonny18gtst said:
Does a series 2 gts grille fit on a series 1 gtst?
No. While I've never tested this, as has been already said the bonnet is different, but so are the headlights. You could pick up an OEM series 2 grille for bugger all if you wanted to test.
I'm looking at guy in a nismo grille all I can get from the seller is its off an ecr33 gts don't know what that even is but mines a series 1 gtst
Gts and gtst are interchangable. GTRs aside all s1 are swapable with all s1 amd all s2 are swappable with s2.
S2 may bolt onto an s1 buy wont look right as the s2 bonnet hangs lower. S1 amd s2 headlights are different but i think its mostly along the top edge BUT they may be different on the side where it meets the grill.
Youll need to find out if the gts is a s1 or s2
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
