The definative way to check the model is using the FAST software from this thread http://www.skylinesaustralia.com/forums/in...++nissan++check
But simply, the Series 1 v Series 2 differences are in this thread, a series 1.5 looks like series 1 but has the series 2 motor (ie no ignitor pack)
its all so confusing!lol
the 1 im looking at , doesnt have the bars in the grill, its just like blank grill with nothing
has round lights in the bar, 1 orange 1 clear.
has a real dark interior...velour i think, and doenst have any real pattern on it
has an airbag steering wheel, but not sure if it has passenger airbag.
do they all have an LSD? or was it only an option?
the 1 im looking at <{POST_SNAPBACK}>
Does the Frontbar look like mine (HERE) (just imagine the other halve) if so it's a series II and yes they are all lsd.
so can anyone list the HARD AND FAST FACTS <{POST_SNAPBACK}>
From what I can gather ofF here the series 1 changed around late 95 to the 1.5 and changed again Jan/Feb to series II. The compliance plate under bonnet will tell you mine says Clicky 02/96 confirmed by FAST.
I just bought an R33 which appears to be a S2, its a january 1996 model. What concerns me is that it may not be a real S2 because it has no ABS or sunroof. Does anyone if the very early S2 come without ABS ?
mate
Series 2 didn't come standard with a sunroof, optional extra. As for the ABS, i think that all series 2 came standard ABS.
Sounds like a 1.5. 1.5 have series 1 interor and exterior (except the rear wing which is a series 2) Drivers side airbag is optional extra on series 1 but standard on series 1.5.
Does the Frontbar look like mine (in avitar) if so it's a series II and yes they are all lsd.
yeah looks the same as that mate...
its a 95 model, but im not sure what month etc....what month did series 2 start if it did in-fact start in 95?
and i dont remember seeing a date on the compliance plate...all i saw was that it was complied by ARDOCK PTY LTD...but ill look on monday
LSD....good stuff :P
mate
ABS was optional on all gtsts including series 2 skylines. more dont have it than do.
http://members.dodo.com.au/paul/pics/mycar...e5/Imgp0450.jpg
thats the normal series 2 skyline front. all series 1.5 cars do not have this front. the bonnet is different also. you can see the lines that go up it
i believe series 1 and 1.5 were in 1995. series 2 only in 1996, 1997, 1998
an optional a-lsd is fitted on some models and the rpm display looks like this
http://members.dodo.com.au/paul/pics/mycar...e3/IMGP0122.JPG
well the R33 GTS-T im looking at buying atm, is a 95, and advertised as a series 2...
has the front bar like yours, but didnt notice those lines on the bonnet, which i cant say im a fan of.
also has reverse EL dials, so i doubt i'd be able to tell if it had an LSD by looking at the tacho..
would a mechanic be able to identify an LSD once its on a hoist?
edit. i think it may have that bonnet, but the angle you took that pic from really emphasised those lines...
if its a 1995 then its a series 1 or series 1.5. no series 2 in 1995
the a-lsd diff has a finned cover around the diff housing. same as gtr v-spec diff. get the vin number and fast will tell you what model it is. it could have just had a front bar swapped for the series 2 front bar. the series 1 and series 2 engines are different and u can visually tell by looking at the throttle body
ive already got the VIN number...what part of it will tell me if its a series 1, 1.5 or 2?
hi all, just my experience. I recently put a sII engine into my r32 and my auto electrician who is abit of a cpu freak used the sI cpu as he reckons that they are more responsive to tuning and more adjustable. Can anyone shed any light on this???
Also, my sII has only slight mods, cat back exhaust, pod. What iridium plug should i use?? BKR5EIx-11 or BKR6EIx-11???
  • 3 weeks later...
Also - don't forget that there is the 40th Anniversary SII.. such as mine :)..
it's got the GT-R adjustable rear wing.. and also mine has a nismo front bar.. which gets rid of the foglights and just has the blinkers..
apart from that - it's also got hicas and sunroof as options.. + 2 x 40th anv stictching in seats.. that's about it. really..
  • 3 weeks later...
Hi all,
I also own a 40th anniversary series II and its pretty much the same as the regular
series II except for the badges and the lip added to the front bar and its midnight purple which ive been told only comes on GTR's an 40th's. Also has factory keyless entry.
Also i'd have to say that ABS must be factory option because a mate doesn't have it in his. a bit strange really.
Edited by Midnight R33
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
