Its just the 40th aniversary edition. Only difference is the badges on the side of the car the seats have 40th aniversary embroided into them plus you have the option of a different front bar. Gearbox is the same.
plus optional GTR rear wing.. plus the usual options.. dual airbags.. hicas.. haven't seen one with an a-lsd.. also there are others including Momo steering wheel.. different gear knob.. "sports exhaust"..
I should print them all out of Nissan fast..
I bought a 40th anniversary and besides the badges it just came with a heap of extras like
factory keyless entry with alarm, factory Skyline floor mats, front lip and the car is
midnight purple. oh and has the light up skyline garnish thats under the boot lid which doesn't
actually work thanks to the previous owner. but thats all i can tell comparing it to my mates skyline
doesn't go any harder.
To add 1 more thing;
I have been told the S2 had a stiffer suspension option, With heavy duty springs.
I have driven a S2 with this apparent option, It was defently differant to the stock setup, Im unsure if it is factory optioned or aftermarket, But several importers have told me its an option.
Any one care to explain?
no cup holder for me
1997 feb series 2 with active lsd
also i think the coin holder thing on the right hand side
was an option on both series 1 and 2, mine doesnt have it
but have seen it on a series 1
I have a 40th anniversary R33 Skyline, some features include:
.Midnight purple
.No coin holder on the right hand side of the dash facia (S1 only I believe)
.Foldable wire cup holder
.GTR Wing
.GTR style front bar
Not necessarily a feature, but the 40th anniversary S2 R33 has a different crank angle sensor to normal S2 R33's....The same Hitachi unit as used by the R34. I wonder if any other engine components are shared?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
