I really need to sell the car due to loss of job and some really big family problems.
If you are interested I am more than willing to drop over for a better look and welcome any inspection.
$17500 atm but am open to any offers.
Less if stock rims are wanted
http://members.optushome.com.au/aqudoctor/car/
http://members.optushome.com.au/aqudoctor/car/1.jpg
http://members.optushome.com.au/aqudoctor/car/2.jpg
http://members.optushome.com.au/aqudoctor/car/3.jpg
http://members.optushome.com.au/aqudoctor/car/4.jpg
http://members.optushome.com.au/aqudoctor/car/5.jpg
R33 GTSt 93
$17500 ono
77000 kms
Power Everything, windows, central locking etc
HiCas
Limited Slip diff
4 Wheel Disc Brakes
T-bar Auto
Adjustable Steering Column
Car is in very good condition, no rattles, rust, squeaks
Work Done
Front Strut Brace
35mm Lowered king springs
17x8 Chrome rims
lock nuts
235/45 all round 50% tread
Cold Air Partion
K&N pod filter with recharge kit
Also have original air box
2 stage Turbosmart boost controller set to 8 psi and 12 psi, Iridium plugs,Timing belt, Water pump, Oxygen Sensor changed at 50000 kms all tuned on dyno
176kw at rear wheels on 12psi
Cooling system flushed and pressure tested 50000 kms
Auto serviced, filter and oil, 65000 kms
Nolothane front struts
Phillips pure white bulbs and parkers
Alpine CD head unit
2way splits in doors
6" GT JBL speakers on rear deck
Spitfire Boost gauge
Ming tint and paint treatment
Mspec front bar, also have original series 1 front bar
Car alarm
Turbo timer
Oil and filter changed every 5000k
3" Zorst from turbo to tip, 5" Tip, with high flow cat
BP Ultimate always used
A/C regassed and tested
Car always driven carefull when cold and turbo allowed to cool down.
No oil leaks.
Cheers
Dave
aka MRE
PM
or
Ph 04177 65681
https://www.sau.com.au/forums/topic/17352-r33-gtst-brisbane/
  • 3 weeks later...
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
