I got a 96 R33 GTS-T Series 2 Manual. After 4500RPM roughly (Hi-boost mode - standard boost), it surges and carrys on till about 6 then kicks in again till redline, change to next gear and it surges again. Its a smooth surge not like a jerking. Very recently done plugs, coil packs, fuel filter, injecters cleaned and other stuff. Any ideas??? ECU???
https://www.sau.com.au/forums/topic/173574-help-surging-r33/
Join the club mate, I have had the same problem with mine since I did the turbo conversion on the 25de, and just about replaced everything. AFM is next tho as its the only thing I didnt replace when I did the conversion. Even splitfires didnt make a difference, tried different ecu's with different maps etc, still no luck
Edited by juddieR31
  • 3 weeks later...
in the last few months its had the following replaced or mod'd:
splitfire coil packs
spark plugs - platinum
fuel pump - walbro
K&N Pod
dump/front pipe
fuel filter
oil & oil filter
clutch
water pump
timing belt
i know most of that stuff wouldnt caus it but thats whats been done, so im guessing its either a fuell pressure reg or an air flow meter now, remember its a smooth surge not a jolting or jerking when detenating occurs,
still bloody stumped and angry
Seeing as you have have tried a lot of different options could be a long shot but i might be your afm, also due to the k&n pod you are using as they are oil based filters, and the oily film can disturb the air folw meter. Pehaps try cleaning your afm and putting a different filter on or standard box.
yeah not sure, was a mechanics job, by high boost i mean stock boost too by the way, but yeah not sure, could be AFM though, what pod should i run then if thats the case? dont they all have oil in em? also i love the look of your 33 'R33silverS2', looks tits
Thanks walta
Get an apexi power intake they are dry filters. :dry: I just bought one for my car.
Edited by R33silverS2
  • 7 months later...
Hey walta did you end up finding your problem?
I was talking to someone else about a similar problem they had and they said it was the Intake hose from AFM into the turbo sucking closed, they resolved it by putting on a silcon intake pipe on.
  • 1 month later...
i agree with evryone those k&n filters especially being oil based will F### your afm it happens on subaru's all the time and you problem with running lean sounds like you ecu not adding enough fuel on boost or cruise and it is surgeing if you have checkd fuel pressure and it is good thats ok could also be dirty injectors or oxygen sensor possibly not reading correctly or your afm running lean on boost and surgeing for fuel mite be worh just getting it checked of a resistance reading could even be coolant temp sensor check it for resistance the higher the temp of the engine the lower the resistance should be just a few ideas
Nothing wrong with the K&N actually. It's because people over oil them, contrary to instructions. So only avoid them if you can't read. :)
hey im having exactly the same problem it all started after resetting my ecu iv replaced plugs and taped any small cracks on the coilpacks my car is still runninh hell rich i dunno what 2 do either pls help btw i have a hks pod its all black and so is all the surrounding parts im guessing after putting finer filter oil on it it may have damaged the afm but i oiled it in november and the problem has only started last week . and it seems as tho it gets worse as it gets colder.
leeboi33 if you think ur new oiled-up pod is is causing problem..
try using some good electrical contact cleaner from ur nearest bunnings/auto one store..
and give ur afm a good clean..
do a search..theres heaps of tips on sau..
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
