Just saved up enough money to be able to purchase another car but i have a hard choice ahead me i am intrested in the above cars, and the requirments out of the cars are 250hp, easily modified and extensive body kit + exterior mod range. So i stuck between the R32 or S13 is well within my budget with a couple of goodies going staright on or R33 or S14 where there will be lack of goodies for a while, tuff choice just after some opinions and thoughts
Thanks Jim
https://www.sau.com.au/forums/topic/173578-r32-or-s13-r33-or-s14/
Id prob say not the s13. Can look tacky with bodykits etc, getting quite dated. s14 is a good choice if its series 2 olther wise the 33 looks the goods with the right kit and can be easily modified to the power level you want. The rb20 in the 32 will take a bit more to get to the same level.
Buy the cheapest 32 you can find that's got decent paint work. spend the rest on an rb25, coilovers, swaybars and whatever else your budget can afford.
imo 33's are the better car only because of the engine. 32 has a better handling and more direct steering.
As for looks it's down to personal preference. i prefer 32 and 34 looks as i think they are fairly simiular tbh. each to there own.
In saying that i had a drive of a friends S14 a while ago and that's only got 180rwkw and it felt very responsive and handled great (lighter car), until smoke came pouring out the back and apparently the turbo gasket had blown.
Since i have one i will go for s14a! DONT GET SERIES I, the turbo aint as good!
Light and cheap, i have been told that fuel consumption is much better than a 33 by a mate and it does make sense!
I cant really compare but im happy with what i got
Unigroup were shocked and said they had never see it before so i dont know if you can go directly by it but i got 203.4rwkw with 16.5psi (yavus still cant believe its a stock turbo because of how easily it was doing it but it is), ces 3" zorst, hybrid intercooler, 040 fuel pump, SAFC II, pod, bov, and other small things. So it took nothing to go up from around 110rwkw, so im very happy with my car, the zorst is the best part since i got the quiet version so long trips are no issue at all! in fact i look forward to them!
Also i dont know why my avatar has rb20e in it!! i didnt put it there so im sorting it out! my car has an sr20 blacktop (stock) just incase there was any confusion!
Edited by Quicksilvia
you probably thought that because 33 steering is the least direct out of all the skylines and silvias. might make the car feel lighter and easier to handle. they revised the steering and made it feel more like the r32 when they developed the 34's. direct steering is better for racing and more assisted softer steering is better for a daily driver.
What do you want the car for? just a daily or a leisure toy...
there is no difference between series 1 or 2 for the S14 in the engine.
if you are making 203rwkw in an S14, you do not have a stock turbo.
even S15's struggle to make 200rwkw with pfc and supporting mods and something like 17psi of boost.
my series 1 made 175rwkw with 15psi boost and safc, fmic, pump, exhaust, pod etc..
same dyno as you.
same tuner as you.
I hate these threads, everyone recomends the car that they own and then bag the others saying rb25>rb20, r33s are boats, rb>sr, etc. It turns into an arguement of who has the best car
get the car you want and like the most
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
