  • Replies 50
Top Gear rated it as their number 1 hot hatch a few months ago. But a lot of readers don't agree. Its like the Yamaha R6 of cars. Fast as f**k on the track, pretty bla on the street. It's also only 2hp more than the Civic Si we get here in the states.
Edited by Rabid
the new civic will be on sale by the end of the month and the launch for dealers was done last night. i got an invite but couldnt be bothered going as ill see it in my works showroom soon anyways.. for more info go to Type R
Damn im sure removing all the safety features and 12 cup holders they install for the 5 passengers you'll drop it down ..
1300kg bluddy hell 100kg off my 34
Might want to take your car to a weigh bridge one day to check that statement. My 4 door is 1560 with no spare, no me, full tank of fuel.
for that wieght do they come with awd and the tune-ability ofa turbo donk ?
the point of an overweight boy racer ?
like sending a teletuby into pro fight with about a months worth of roids in it...
hahah threads like this always turn into "compare this to a turbo car" thread.
I reckon it's a great package Honda's got there, funky looking exterior with well matched interior and a fairly decent engine for a good time.
if my friend every decides to buy that Accord Euro he wanted, I'd go with im just so I can test this one out.............and the s2000
it needs to lose some weight, namely the massive wheels, could go with one size smaller which should save a bit of weight. Maybe get rid of all that electronic gagetetry.
Still don't know what makes up all that 1300kg............must be the enlarged displacement........it is enlarged isn't it?
It has a lot more options than the older Type R's. 18" wheels stock, with options for 19's and I don't think the wheels are where its picking up the weight. With forged wheels you only gain about 1lb per inch, so for example 20" wheels weigh in at about 20lbs, so 18's are roughly 18lbs. It also has Electronic Brake Assist and Vehicle Stability Assist and a super nice interior with Alcantara seats. But its also loaded on safety options like 6 airbags and thats a lot for a car with only 2 doors. Even at 1267kg it still manages to have 156hp/tonne and pulls off a 6.6sec 0-60, so its not exactly slow.
It's still a 2.0-litre VTEC motor rated at 198hp @ 7800rpm and 142lb-ft torque @ 5600rpm.
It's a pretty nice car overall and the 'hot hatch' category is by far my favorite (I've owned 6 zippy hatch's in my life), but I still think id go with a Ford Focus ST over the Type R, even though you cant get either one here in the states :bunny: .
I would like to see a 3 car battle between the Euro-Spec Type R, the Jap-Spec Type R, and the American-Spec Si. Our Si is only 2hp less than the Type R, so it might make for an interesting battle. Looks better too, in my opinion anyways.
I work for a Honda dealer the new tyre r's only came into stocktwo and a half weeks ago in auss, they look absoutly nuts in real life, a bit heavy but the car hadles so soo well, could do with a little more power the early thoughts werfe going to be i-vtec and turbo mmmm woulda been way better. as for price they reatail at 39,990+ on roads. comes only in 18"s cant option different wheels, they only come in 3 colours black silver and red, and as for seats cant remember the brand they arnt recaro but they look way better and are soooo comfy.
although all that said i'd take a gtr or even a gtst anyday. stock for stock that is
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
