Hey, doing a manual conversion of a cefiro a31, not very onto it with nissans (rb20e)
But, we put locktight on the flywheels bolts, to realise these c**ts have spigot bushes, will it be easy to crack the bolts again??
Whats your tips for getting the bush out? Best option?
Also, what you guys use to align the clutch (if you dont have a clutch aligment tool)
Last, Whats that big red cable what looks to be 8guage, what comes off the gearbox with a metal mounting on the end, an earth?? Its long.. (on the manual) thanks!
https://www.sau.com.au/forums/topic/173611-manual-conversion-problems/
k here we go
1.But, we put locktight on the flywheels bolts, to realise these c**ts have spigot bushes, will it be easy to crack the bolts again??
just leave it one there you should be able to get it out
2.Whats your tips for getting the bush out? Best option?
id use a little bearing puller. or you can use a screwdriver an hammer and be rough. is it buggered and need replacing?
3.Also, what you guys use to align the clutch (if you dont have a clutch aligment tool)
i use a imput shaft out of a nissan gearbox
4.Last, Whats that big red cable what looks to be 8guage, what comes off the gearbox with a metal mounting on the end, an earth?? Its long.. (on the manual) thanks!
its probly an earth cable. i dont know cos i dnt have one
    • I need 2 new pre-cat O2 sensors for the 528. I'd like Bosch but they're all for >9/98 and I'm a lowly 6/98 build. There's not many other options available unless I go cheap Chinese and I'm not keen to do that. Genuine BMW is an option too but they'll likely cost more than the car is worth. Automotive Superstore and Autobarn sell PAT O2 sensors. I know nothing of this brand but they're a little pricey (~$160ea @ AS) and that usually tricks me into thinking something is better than it is Any opinions here? Thanks.
    • How do they go in the rain when flooring it? They sorta look like a semi slick.
    • Contains some of the same waxes that are in the Meg's gold wax anyway. Your car is white? Wax won't make it look "cloudy" enough to worry about it. Just put wax on it and decide if you think it looks cloudy. I would bet you couldn't tell. If you want to follow the paint shop's advice, then you'd be looking to ceramic coat the paint first. Then wax on top of that (although the ceramic coat purists would say that you don't need to wax on top of ceramic - I'm not in their camp). I am of the opinion that ceramic coat should only get put on top of paint that has recently been properly corrected by an expert, or thereafter as maintenance. But wax can be put on anything and keeps the nasties away from the paint and can either be removed easily enough, or comes off on its own over time - unlike the ceramic, which you can have a hard time knowing what condition it is in. Um, what? Fuel stain? On the rear bumper? Please explain.
    • I liked them too, but somehow they were not quite as good as the preceding RS3, and I vastly prefer the Yoko AD09s. Quieter, longer lived, more progressive, damn near as sticky. And they don't howl like the 'Kooks do when they're mostly worn.
