-Year/Make/Model: 1998 Nissan Skyline R34 GT-T (GTT) NISMO SPEC
-Engine: Neo Straight 6 RB25DET 2.5 Ltr (Turbo)
-Kilometers (KMS): 60,000kms
-Color: White
-Transmission: 5-Speed Manual
-Rego: June AZT-24W
-Engine Modifications:
-Serviced every 5,000km have log book which have been serviced by bels garage reciepts all kept.
-HKS super induction pod filter with factory air scoop Aftermarket high volume grounding kit
-Excedy heavy duty clutch
-Nismo exhaust 3" cat back
-High volume grounding kit
-Interior Modifications:
-G-Reddy Profec B dual stage digital boost controller low 7psi & high 11psi
-Blitz digital turbo timer with dual setting and other functions
-Alpine MP3 head unit with Alpine 6 Cd stacker
-12 inch Clarion sub
-700 Watt Clarion amp
-Aftermaket dual cup holders
-Mongoose 3 point immobliser & black wiring alarm plus window lifters & central locking
-Sport & silent mode for exhaust
-Standard stock Interior
-Exterior Modifications:
-Factory standard Nismo Aero front bar which looks aggressive
-Nismo fog lights
-Nismo eye lids had been ordered from Japan, have been sprayed with colour matching paint and fitted
-Nismo side skirts
-Nismo side clear indicators
-Nismo rear bar
-Nismo exhaust with silent & sports mode run by a switch
-Car is well maintain inside and out with no scratches, never been in accident, Inspections welcome
-Wheels & Suspensions:
-Standard 17" Rims with Bob Jane T-Mart, Maxius 90% tread on all 4 tyres with life time warranty on alignment.
-Castor rods had been changed
-Machined front disc & replaced front pads with Bendix Ultimates
-Factory Options:
-Dual air bags
-Factory tinted windows
-Cup holders x4
-Fog lights
-9 storage compartments
-Central locking
-Space saver wheel
-Alarm
-Traction control
-Other Information & Comments:
-1 of the best original Nismo Aero Spec R34 GT-T out there, dont be fooled by aftermarket kits, this is 1 is genuine and kept in best -condition in & out, 1st see will buy. Regretful sale due to fiancial problems.
-NO TIME WASTERS OR JOY RIDERS PLEASE,
-May swap, open to suggestion
-$23,000 ono
-Call 0415715062 William
https://www.sau.com.au/forums/topic/173619-23000-for-gt-t-r34-ono/
Guest
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
