Guest INASNT
As most of you might know i am doing an upgrade on alot of the components of my car. The only thing i am undecided on is the turbo.
Does any1 know if all the internally gated HKS turbos have the same dump pipe flange eg 2530, 2835 pros s, 3037 pro s or are they all different?
What about the Garret ones are they similiar or all different?
Cheers
https://www.sau.com.au/forums/topic/17362-dump-pipe-flange-differences/
Guest INASNT
Originally posted by robertr
Garrett make a GT40 bolt on with internal waste gate on the AR 1.06 rear wheel one.
I have one
GT40 bolting down in the stock location??
hmm do tell me more, but 1.06 rear A/R must be lag city?
what are the costs involved and what about water and oil lines lining up to stock location?
Guest robertr
Dynamic turbo chargers
Speak to a guy called Steve on (02) 9757 2766
Tell him that Robert from Bar None Motors up in Forster said you would look after him regarding price and service
The flange is T3 which is standard RB25 size
...and let me tell you it looks really horny.
Guest INASNT
i dont think i will be driving all the way to sydney just to get a turbo supplied!
It may be T3 flange but if the housing is 2 big it wont fit properly in thestock location with using a spacer plate!
take some pics of it and what price is he charging u for supply and installation?
Guest robertr
Hi INASNT
Since I do a lot of work with them my price will be different than yours.
However there is a solution. How about you looking around and getting your very best price and then i'll ask him to beat it! Just be honest, as I know how much they are selling for.
This 1.06 AR rear GT40 is will fit the std manifold with a spacer as the compressor cover is only 1/4 inch bigger in diameter than the TO4 that came off the car. Spacer will be approx 12mm.
Specs are:
4" intake
2.5" output
3" exhaust + the wastegate opening (around 2.5")
The spool up will not be as good as the .82AR rear however I wanted the 700 turbo to big me a big hit from 4,500 on up and not run out of puff through the to high rpms.
Pics of turbo off and on car will come soon.
Guest robertr
INASNT: Re lag city.
Just the way I like my turbo charged cars to run. With my mods, it should be biulding 14psi boost by 4500.
I'll let you know more soon but for now the plans to have it ready has blown out to Thursday next week.
The fuel pump was ordered incorrectly and getting another up with take till Wed. BUGGER!
Guest robertr
yeah you are right. I couldn't believe it. Just had to try it out. The wastegate is quite big so it will be fine I believe. Also, we are going to run a screamer pipe so should sounds a hoot.
Oh and BTW, it is much cheaper as you can understand as you don't need any change of manifold or spacer for the external W/G. The wastegate alone is no cheaper than $600 say for a good sized W/G.
That all adds up to a super deal for the lastest "big" Garrett turbo don't you think?
