Can anyone provide me with the latency times for nismo 555cc RB25DET injectors please?
I reckon it would be sweet if there was a database for the most common injectors latencies and whatnot...
Double that request for Nismo 555cc injectors latencies.
I can't find that data anywhere.
come on.... someone must have latencies for yellow Nismo 555cc injectors.
Must be the one of the most common upgrades.
If anyone has them please have look in your PFC hand controller and see latency your tuner has used.
There are three people here waiting for this and probably more that will benefit from this information.
It will at least let us drive our cars down to the tuning shop with some peace of mind that the fueling is not excessively lean.
Once my car is tuned I will post up the latencies my tuner has used.
have you not tried googling? nismo 550cc lag time nismo 550cc latency etc. keep going till you find it, the truth is out there. That's what I've done every time I needed to know and injector lag time and it's never failed me.
Yep, tried the google. Nismo 555cc get a few more hits than 550cc but still no success.
Heaps of forum discussion, no solid data.
- Japanese instructions do not mention anything.
- No data on Nismo website.
- PaulR33 FAQ does'nt list 550cc Nismo injectors unfortunately.
(http://paulr33.skylinesaustralia.com/docs/powerfc-faq/powerfc-faq.htm)
If anyone is running yellow Nismo 550cc injectors the sharing of their PFC latency setting in this thread would be appreciated.
Incorrect latency settings can be fixed by compensating the fuel map but that is a less than satisfactory outcome to my mind.
Only data I can find is 0.710ms. However, I would personally prefer a more reputable source than this random thread. :(
http://forums.freshalloy.com/showthread.php?p=1452662
HAHA sorry i forgot :D
nismo 550cc 0.71 :P
Std lag times to calculate differrence; (for some reason i lost my second decimal place :( i will fix it asap
RB26DETT
440cc
0.77ms
RB25DET NEO
380cc
0.6ms
RB25DET NEO
380cc
0.7ms
RB20DET
260cc
0.7ms
SR20DET (s15)
480cc
0.5ms
SR20DET (s13)
370cc
0.7ms
SR20DET (s14)
370cc
0.7ms
CA18DET
370cc
0.6ms
2JZ-GTE
440cc
0.9ms
3S-GTE
540cc
0.5ms
4G63 (1-4)
510cc
0.8ms
4G63 (5-8)
560cc
0.8ms
13B-REW
prim 550cc
0.8ms
sec 850cc
0.7ms
EJ207 Sti
520cc
0.7ms
BLITZ PERFORMANCE INJECTORS
UNIVERSAL
1000
1.00
RB26 / CA
700
0.65
RB26 / CA
660
0.55
RB26 / CA
534
0.85
1JZVVTI
525
0.99
1JZ / 2JZ
540
0.56
SR / RB25
550
0.85
SR / RB26
850
0.85
2JZ
850
0.85
Interesting thread. My experiences with nismo 550's on a sr20 was that they lost the ability to deliver fuel properly below 1.45-1.55ms. That was firing the injectors sequentially on low impedance injector drivers.
So I am guessing the 0.71ms latency means time for the injector to change from closed to completely open... and not back to closed again.
I've read that some sard regulators are stable down to 1.1ms with stable fuel delivery, so the latency has got to be close on 0.45-0.5.
Cheers,
Ian
WTF... do nismo even make 550? isnt it 555cc? anyway.. im after the EXACT Latency times For Nismo RB26DEtt 555cc injectors. to re-configure the Power Fc..
Thanks Guys,
If anyone has 555cc injectors on the power fc and run them on an RB26DETT please goto your car and check the Latency time set into your hand cntroller hanks guys.,
  • 7 months later...
Hi Guys
Sorry to bring up an old thread, but i need a bit of help.
I will be installing my nismo 555cc injectors and setting up my power fc for the injectors in the next couple of weeks (running a HKS 3037 Pro S and all the supporting mods) before i book it in for a tune, i have worked out the injector correction and injector latency correction numbers that i need to change in the PFC, can somone please comfirm for me that these are 100% correct? :D
"INJECTOR CORRECTION"
- Formula = stock 370cc divided by nismo 555cc = 0.66cc x 100 = 66%.
So i would go into the power fc and change the INJ correction to 66%, correct?
"INJECTOR LATENCY CORRECTION"
From what i have found the latency for the nismo's is 0.71msec and stock is 0.52msec
- Formula = nismo 0.71msec minus stock 0.52msec = 0.19msec
So i would change the INJ Latency numbers for each injector to 0.19msec, correct?
Hopefully this can help people in the future that are looking for the correction numbers :).
By the way, someone should sticky this thread!!
Cheers
Edited by nizmo_freek
    • Jamie does know his stuff , you might just want to give them a call and ask - here is their FB page  -  https://www.facebook.com/profile.php/?id=100063506985512 - you will find the number to call them on.
    • Do you think the guys in Penrith are install the E85 Kit?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
