Hi Guys
Sorry to bring up an old thread, but i need a bit of help.
I will be installing my nismo 555cc injectors and setting up my power fc for the injectors in the next couple of weeks (running a HKS 3037 Pro S and all the supporting mods) before i book it in for a tune, i have worked out the injector correction and injector latency correction numbers that i need to change in the PFC, can somone please comfirm for me that these are 100% correct? :)
"INJECTOR CORRECTION"
- Formula = stock 370cc divided by nismo 555cc = 0.66cc x 100 = 66%.
So i would go into the power fc and change the INJ correction to 66%, correct?
"INJECTOR LATENCY CORRECTION"
From what i have found the latency for the nismo's is 0.71msec and stock is 0.52msec
- Formula = nismo 0.71msec minus stock 0.52msec = 0.19msec
So i would change the INJ Latency numbers for each injector to 0.19msec, correct?
Hopefully this can help people in the future that are looking for the correction numbers :D.
By the way, someone should sticky this thread!!
Cheers
i did not check your maths but the theory and formula's are correct.
therefore if your maths is correct you are ok to go :rofl:
deatschwerks 450cc RB25det sidefeed injectors
Min Open time (ms) max idc 6v 7v 8v 9v 10v 11v 12v 13v 14v 15v 16v 17v
1.1 94% 5.89 4.48 2.97 2.25 1.88 1.73 1.46 1.37 1.25 1.12 1.09 1.02
deatchwerks 550cc RB25det sidefeed injectors
5.88 3.50 2.62 2.07 1.80 1.56 1.42 1.32 1.19 1.11 1.07 0.95
I'll check mine, I have 555cc Nismo's running.
I found anything under 0.30ms and I couldn't do a thing.
They were really hard to set.
You can have my settings if you want, they seem to work perfectly.
I think its 77% and 0.44msec. I'll double check on my way home this afternoon.
Sounds good :banana:, would be good to have your settings just incase mine dont work when i put my numbers into the power fc
Any idea why yours only work on 0.30msec? did you try the 66% and 0.19msec (using the formula in the power fc FAQ) before adjusting them yourself?
Is anyone else using nismo 555cc's able to go into there PFC and check what settings they have theirs set to? would be a big help!
Cheers
  • 3 weeks later...
I just finished installing my nismo 555cc injectors, i set up the injectors settings in the PFC like this: injectors correction = 66%, latency correction = 0.18msec (when i worked this out i came up with 0.19msec but the PFC latecy correction only goes up in 2's so i had to choose either 0.18msec or 0.20msec, i tried both and they didnt seem to be much different).
Started the car and it seems to run ok, i havent driven it, have only had it idling, it seems to idle "ok" but it is a bit rough, does this sound normal? is it just running a bit to rich? it dosent seem to smell overly rich.
Im dropping my car off to the tuners on monday so imtrying to get everything running the best i can so he dosent have to spend to much time stuffing around with it.
I got this figure from Google as i wanted to get the 555cc NISMO injectors for my GTS25t as well. Latency is 0.75msec. So settings for my Apexi Power FC are calcutated as such;
370 / 555 = 0.67 x 100 = 67%
0.75 - 0.528 = +0.222msec
Something like that.
Edited by teng
I just went out and started my car up again just to see how it was running, took two goes to get it started, still idling very lumpy, also it is now "spitting" lots of white smoke out the exhaust and smells super rich, almost like its just spraying pure petrol out the exhaust, it dosent idle to bad just a bit lumpy and rough, took out #1 spark plug and it was a little wet and smells of fuel.
Will the white smoke just be from it running way to rich? i always thought if it was running too rich it would have been black smoke, the smoke dosent smell like oil at all.
I think i might just leave the settings how they are now, even though its not running to great, im sure my tuner will be able to sort things out.
ok well i'll tell you my experiences...
I was using the default setting for what should be correct for the nismos 555ccs: being 66.5% and 0.18ms.
my car (r33 rb25det) was running way to rich so now im still running 0.18ms latency but 60% injector size correction. i once read that the factory injectors are 340cc not 370cc.
has anyone ever actually measured them??? or got this info from nissan?
Just had my car tuned a couple of days ago, he left used the injector settings that i had already set up in the PFC.
So just to clarify for future rb25det owners in the process of setting up their PFC for nismo 555cc injectors, use these settings, just like shown in the PFC FAQ
INJ correction = 66%
Latency correction = 0.18msec
Hope this helps people in the future!
Cheers :thumbsup:
  • 1 month later...
So what would be the correction for:
Going from 555cc to 740cc Nismo?
ignore the fact you have 555 and refer to the simple formula divide the original injector cc by the new injector cc. In your case 50%
  • 4 months later...
hey guys
i finally have some nismo 555cc injectors for my R32 gtst with rb20det. I am running a remaped ecu at the momment and will be changing over to the pfc pro i have laying around and these injectors before i drive it most likely to godzilla motorsports for a tune.
I am trying to work out two things so i can drive it there. What the new injector correction and latency is, and also if i need to add a gtr resistor pack when i install the injectors. I am only second guessing things because i noticed they have the same part number as the 555s for the 32 gtr. I purchased them from greenline and they didnt say anything about needing one but i didnt ask either.
I have read thru the pfc faq (thanks paul), and from what i can work out the correction and latency is something like this:
Old SIZE / New Size = Correction
New Latency - Old Latency = Latency Correction
So i think rb20 stock is
260 / 555 = .4684 * 100 = 46.8468%
.? - .71 = ?
So basically i dont know the latency for the nismo 555cc injectors when they are for the rb20det, i think most of the info in this thread is for the yellow rb25 ones :rolleyes:
Cheers guys
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
