-first, put some oil on the inside of the bolt and on the thread so there is minimal friction when using the torque wrench.
-tighten the bolts to around 16N0m (1.4 - 1.6kg-m)
-then tighten the bolt an extra 60-65 degrees using a protractor fitted to your breaker bar (use a breaker bar instead of a rachet so your angle is constant as a breaker bar doesnt click back and wont snap under high torques).
cheers.
https://www.sau.com.au/forums/topic/173707-bolt-torque/#findComment-3191821
did mine to 40ft lbs.
if your after the exact on satndard bolts as mine are arp bolts, i have the workshop manual downstairs.
let me knwo if you get desperate, or call your local engine machine shop. they always know!
cheers Garth
https://www.sau.com.au/forums/topic/173707-bolt-torque/#findComment-3197109
