hey all jus came back from his sellers place in inner west (close to bankstown) and the parts available are genuinely there. great guy with good attitude... and i hope seller doesnt mind that i post his contact number up so everyone can stop making posts about it.
contact number: 0416 554 283
looks like alot of trim parts are gone, driver's seat is gone, no floor matts, no rear seat, side mirrors are there, rear lights are there, anything front right of car is pretty much gone, radiator gone, motor is good, doors there, windows there...err..dash is there.....it is a WHITE coupe, NON TURBO.
hope that has saved alot of unnecessary questioning and just call him if you need anything, he wont bark.
great seller! :yes:
Dom
  • Replies 50
hey where in sydney you located? i need a bootlid key hole nissan thingo (blew mine out with the sub :rant: ) probs need front rotors as well (well need the drivers side one more...
rofl! aheahea is that even possible?
ur sub must be powerful!
lol
Updated price list.
Rims with 80% tread on all four - $600 Price drop $500ono
Bootlid - $100
Spoiler - $80
Rear bar - $150
Tail lights - $70 each
Window regulator - $80 each
Steering wheel no airbag type - $80
Dash cluster 128kms - $80
RB25det Airbox SOLD
Passenger side gaurd SOLD
Interior - $200 complete will seperate parts
Passenger pwr window switch - $50
Driver side pwr switch - $60
Rb25de - $500ono
Dash cluster surround - $50
Parcel tray - $50
Passenger side door - $100 without reg or door trim
Ignition barrel, key and matching door locks - $100
Climate control unit - $40
Floor carpet - $50
Middle console - $30
Rear window - $80
All prices are negiotiable.
PM for any other parts as car is complete.
Cheers
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
